Flash Fig Help
I have a switch that’s running router os 7.8 that I was hoping to export the config to a file and then use that file to flashfig the same switch but on 6.48
Would this cause a problem. Also a side question,
Once you do a flashfig with
Flash boot once and nand.: does that mean now the reset button will always use that config?
Thanks for the help.
