Hi Guys N Gals
I’m writing a script which will be running every few min on the Tik and i’m using the fetch command to get some info
however i’m just wondering can I store the result to a variable rather then to the flash as I don’t want to kill the flash
contastantly rewriting.
The result being kicked back from the fetch is only a few Kb so there is plenty of space there in RAM.
anyone got any suggestions?
You can’t do that.
Fewi thank you very much for the quick reply
