'flash' takes all available CPU with The Dude on RB751
I installed The Dude 4.0b3 on a RB751 running 5.7. This is to do some simple ping tests to some servers on the internet. Immediately after the reboot which enabled the Dude (before it had any configuration), I see:
/tool profile
NAME                    CPU        USAGE
wireless                all           0%
ethernet                all         0.5%
console                 all         0.5%
flash                   all          95%
ssh                     all         0.5%
firewall                all           0%
winbox                  all           0%
dude                    all           1%
management              all         1.5%
dhcp                    all           0%
profiling               all           1%
queuing                 all           0%
bridging                all           0%
unclassified            all           0%
So ‘flash’ is taking all available CPU. This began as soon as I did the initial reboot of the routerboard and before I did any actual configuration from within The Dude. Anyone else with similar issues?
i will not install the dude on RB75X series. lack of space, and RAM.
also, the dude 4.0b3 is buggy, it crashes a lot, i used to use it on my x86 ROS. i replaced it back to v3.6, and it is not crashing anymore.
I moved to Dude 3.6 and it’s been fine. The ‘flash’ and ‘dude’ processes go up when you do any type of network scan, but with a few hosts added doing ping and http checks, as well as showing interface speeds it’s totally fine.
One additional comment. I have 4.0b3 running fine on an RB450 (non-G) which also has 32mb RAM. This device does not experience issues like the RB751 does.
make a supout.rif file at the moment when “flash” is acting up, and send to support.
