flashing eth lights on RB192
Hi everybody.
I recently bought RB192 and from its configuration, the random freezes on the device .
Symptoms: the ethernet ports from the device stop responding showing me all the flashing lights. The only way I can get access the router is by serial console.
Notes:
  1. I have configured 1 (ether1) with a WAN link, 1 bridge interface with ether2 and ether3 ports. The other interfaces are disabled.
  2. Only one (just for testing) NAT masquereding rule.
  3. I did setup watchdog on my gateway just for generate autosupout.rif file, and reboot to prevent out of service.
I´ve got routeros v3.11 with 2.16 firmware installed on RB192.
Any ideas?
LOOKING FORWARD TO HEARING FROM YOU SOON.
I will thanks your advice.
I solved following this steps:
  1. exporting configuration
  2. formating the disk
  3. flashing the firmware
  4. importing configuration
Conclusion:
truly never hang again. :sunglasses:
