I’m new to Mikrotik and learning.
I have two CRS328-24P-4S+RM switches.
I’d like for both switches to be part of a flat 192.168.1.1 network to start testing with, where 1 of the switches is connected to my RT-AC68U SOHO internet access point that does DHCP etc. Both switched have unique static IP addresses that fit inside 192.168.1 and are outside of the DHCP range.
I’ve connected sfp-sfpplus1 & 2 on each switch with 10G cables.
I’ve set both switches in bridge mode. I’ve removed sfp-plus1&2 from the bridge, made a bonding and then added the bonding back to the bridge on both. I can see they can communicate although the internal bandwidth testing tools in RouterOS don’t show more than 300Mbps speed, which should be higher I guess.
What doesn’t work right now is that I put one 1G cable into one switch, connect that to the RT-AC68U and then go with a laptop to try to connect to the other switch. The first switch I can see and access, but I cannot reach the second switch through the 10G bonding link.
RouterOS is 6.43.8 (stable) on both CRS328s.
Questions:
- The quickset screen shows a mode option for Router and Bridge. I did not set an IP in my router mode page. When I click on the bridge mode page I have a static IP and can reach the switch.
Does RouterOS remember I want both switches in Bridge mode, and have set that? Why it is always coming up in quickset with the Router mode selected instead of the Bridge mode I configured? - Is the config correct on both switches, where I set it to bridge, have all the interfaces in bridge, but for the two sfp-sfpplus1&2 interfaces, which are in a bonding and then added back to the bridge?
- did I miss setting some configuration that will allow me to traverse to the second switch over the 10G bond?
- Can this work with one flat network, or will it only work if I do more complex things with VLANs and Firewalls on these switches?
I have orders some books on Mikrotik Router OS so I can learn more. I find the manuals online confusing since they do not seem to have caught up with the screens I can see in 6.43.8, but I guess everyone likes the CLI in networking, where I am more a GUI person
Hope the forum can help a newbie with some simplistic configuration. I promise to learn fast, didn’t buy these CRS’ for shelfware.
