I have a small capsman setup with three CAPs but running into user visible issues with a wifi client. It seems to me like it switches between two CAPs very often which also results in reported breaking connections which I do not really expect with capsman at all.
The logging when that happens looks like this:
08:25:31 interface,warning ether4-Office: bridge port received packet with own address as source address (cc:2d:e0:c2:cf:8e), probably loop
08:25:35 dhcp,info default assigned 192.168.250.120 to 2C:0E:3D:26:75:C7
08:26:18 caps,info [::ffff:192.168.250.251:38207,Join,CAP-6A347E5C9611] joined, provides radio(s): CC:2D:E0:C2:CF:8E,CC:2D:E0:C2:CF:8F
08:26:18 caps,info dg-2g: selected channel 2452/20/gn(20dBm) (fixed)
08:26:18 caps,info dg-5g: selected channel 5180/20-Ceee/ac/P(23dBm) (fixed)
08:26:26 caps,info 2C:0E:3D:26:75:C7@dg-2g connected, signal strength -62
08:26:26 caps,info 2C:0E:3D:26:75:C7@eg-2g disconnected, registered to other interface
08:26:28 interface,warning ether4-Office: bridge port received packet with own address as source address (cc:2d:e0:c2:cf:8e), probably loop
08:26:34 interface,warning ether4-Office: bridge port received packet with own address as source address (cc:2d:e0:c2:cf:8e), probably loop
08:26:35 caps,info 2C:0E:3D:26:75:C7@dg-2g disconnected, interface disabled
08:26:38 caps,info 2C:0E:3D:26:75:C7@eg-2g connected, signal strength -77
08:26:45 dhcp,info default deassigned 192.168.250.120 from 2C:0E:3D:26:75:C7
08:26:45 dhcp,info default assigned 192.168.250.120 to 2C:0E:3D:26:75:C7
08:26:58 caps,info [::ffff:192.168.250.251:49277,Join,CAP-6A347E5C9611] joined, provides radio(s): CC:2D:E0:C2:CF:8E,CC:2D:E0:C2:CF:8F
So from that log it almost looks like the CAP-6A347E5C9611 loses connection to capsman and that is the reason why the client jumps around?
Is this caused by the loop warning? Both CAPs are connected to capsman via that ether4-Office interface and the reported source address is one of the two wireless interfaces of the CAP which is reported to join frequently.
Any idea what happens here and what would cause it?
ok, so it’s really the cap losing connection:
log from the cap
08:26:35 caps,info CAP disconnected from MikroTik (::ffff:192.168.250.254:5246)
08:26:37 caps,info CAP selected CAPsMAN MikroTik (4C:5E:0C:06:EA:46/6/0)
08:26:57 caps,info CAP connect to MikroTik (4C:5E:0C:06:EA:46/6/0) failed: timeout
08:26:57 caps,info CAP failed to join MikroTik (4C:5E:0C:06:EA:46/6/0)
08:26:57 caps,info CAP selected CAPsMAN MikroTik (::ffff:192.168.250.254:5246)
08:26:58 caps,info CAP connected to MikroTik (::ffff:192.168.250.254:5246), CommonName 'CAPsMAN-4C5E0C06EA44'
08:26:58 caps,info CAP joined MikroTik (::ffff:192.168.250.254:5246)
the other cap does not have the same issue while it’s connected just to a different switch port behind ether4-Office.
I cannot explain the connectivity issues so far
And even more information.
The whole thing seems to only happen when this certain device 2C:0E:3D:26:75:C7 moves to this certain CAP. I’m not sure if it only happens on 2G or also the 5G interface. At least there is another device registered at 5G permanently which does not trigger the behaviour.
The hardware is a hAP ac^2.
Latest summary after more testing:
Whenever a client connects to the 2G interface on the CAP it loses connection to capsman. Problably because of
This warning only reports the 2G interface always so I think this might be the reason for capsman to disconnect as soon as a wifi client connects to that interface?
Still I do not get what the warning means. The interface’s data path is the local bridge which also contains ether4-Office.
I had similar issue (with disconnection, not caps/capsman) when i used same config for several devices and my virtual wlan accidentally used same MAC. (because config was exported from first device and i didn’t notice this)
Try to check, if all interfaces have unique MAC. (simple /interface print should give you list of all MAC’s within one device)
The bridge does not seem to allow me to change the MAC? At least not in Winbox.
And the MAC itself seems to be the legal one for the wlan1 interface. I actually could change it to something but not sure what the “right way” to fix is.
Found the issue. The wlan1 interface was locally part of the wrong bridge (actually not really as it was controlled by CAPsMAN and even if it would be a local interface it would be correct on that bridge). The bridge then decided to use exactly the MAC of the wlan1 interface while there would have been other better choices At the same time CAPsMAN also uses the local interface’s MAC and so the same MAC was somehow local on the CAPsMAN and coming from the CAP at the same time. Now I’ve put the wlan1 into another not used bridge locally to avoid bridge using exactly this MAC.
It is common that bridge use same MAC as one of devices connected to it (the lowest one to be specific). You can disable it by setting admin-mac (or “Admin MAC address” in winbox) manually.
Having same MAC for interface and bridge (where this interface is connected) does not usually cause issues. However, if same MAC appears in two different devices, they will under some circumstances incorrectly detect loop and disable connection for a while.
