I put a few usb flashdrive to my mikrotik, and Mikrotik created folders for that flasdrives named
disk1
disk2
disk3
I noticed that the folders still exists, even if I remove and reboot the router.
After reboot that folders are alway created, but please notice that I do not have any usb flashdrive inserted:
[admin@Mikrotik] > /disk print
# NAME LABEL TYPE DISK FREE SIZE
[admin@Mikrotik] > /file print
# NAME TYPE SIZE CREATION-TIME
0 flash disk jan/01/1970 01:00:00
1 disk1 disk jan/01/1970 01:00:02
2 disk2 disk jan/01/1970 01:00:02
3 disk3 disk jan/01/1970 01:00:02
When I remove it is OK:
[admin@Mikrotik] > /file remove disk1
[admin@Mikrotik] > /file remove disk2
[admin@Mikrotik] > /file remove disk3
[admin@Mikrotik] >
But after reboot I see that folders are created:
[admin@Mikrotik] > /system reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
And after reboot I see:
That is normal?
How can I remove that folders completely?
BTW, I noticed bug that when I put some on usb flasdrive to Mikrotik, when mentioned folders are created that this flashdrive will not be mounted till I remove manually that folder.
Does it normal too?
