So i have OPNSense as gateway,firewall and dhcp/dns server. Mikrotik Hap Lite is acting as managed switch.
Tagged Vlan on Wifi works, but on the ports it doesn’t. I have tried all written scenarios from this forum and manual and i just cannot get additional Vlan to work.
Here’s setup:
OPNSense 192.168.1.3
default network 192.168.1.0
Vlan 20 - 192.168.20.0 (works)
Vlan 30 - 192.168.30.0 (doesn’t work, see below case)
Mikrotik 192.168.1.2
Ether1 connected to OPNSense
Ether2 laptop (192.168.1.0)
Ether3 IPTV (192.168.1.0)
Ether4 Vlan30 (192.168.30.0)
Wlan 192.168.1.0
Wlan2 Vlan 20 (192.168.20.0)
So with this configuration from the guides, Vlan30 doesn’t work, node on Ether4 doesn’t get IP or doesn’t pass traffic
/interface bridge add ether-type=0x88a8 fast-forward=no name=bridge1 vlan-filtering=yes
/interface wireless set [ find default-name=wlan1 ] band=2ghz-g/n disabled=no mode=ap-bridge ssid=MKTK158
/interface vlan add disabled=yes interface=ether4 name=vlan30 vlan-id=30
/interface list add name=WAN
/interface list add name=LAN
/interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/interface wireless security-profiles add authentication-types=wpa-psk,wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=iot supplicant-identity=""
/interface wireless add disabled=no keepalive-frames=disabled mac-address=**** master-interface=wlan1 multicast-buffering=disabled name=wlan2 security-profile=iot ssid=IOT_SH_158 vl
an-id=20 vlan-mode=use-tag wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface bridge port add bridge=bridge1 interface=wlan1
/interface bridge port add bridge=bridge1 interface=ether1
/interface bridge port add bridge=bridge1 interface=ether2
/interface bridge port add bridge=bridge1 interface=ether3
/interface bridge port add bridge=bridge1 interface=ether4 pvid=30
/interface bridge port add bridge=bridge1 interface=wlan2
/interface bridge vlan add bridge=bridge1 tagged=wlan1,ether1,ether2,ether3,wlan2 untagged=ether4 vlan-ids=30
/interface ethernet switch vlan add disabled=yes ports=ether1 switch=switch1 vlan-id=30
/interface list member add interface=ether2 list=LAN
/interface list member add interface=ether3 list=LAN
/interface list member add interface=ether4 list=LAN
/interface list member add interface=ether1 list=LAN
/interface list member add interface=wlan1 list=LAN
/interface wireless access-list add interface=wlan2 mac-address=***
With this configuration which i am sure is not correct per this artcilehttps://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration#VLAN_on_a_bridge_in_a_bridge , all Vlans work and i can ping node on Ether4
/interface bridge add fast-forward=no name=bridgeVlan
/interface vlan add interface=bridge1 name=Intrerface-vlan30 vlan-id=30
/interface wireless add disabled=no keepalive-frames=disabled mac-address=******* master-interface=wlan1 multicast-buffering=disabled name=wlan2 security-profile=iot ssid=IOT_SH_158 vl
/interface bridge port add bridge=bridgeVlan interface=ether4 pvid=30
/interface bridge port add bridge=bridgeVlan interface=Intrerface-vlan30
/interface wireless access-list add interface=wlan2 mac-address=******
Mentioned OPNSense just to say that it is handling IP addressing not Mikrotik.
I follow what you suggested and network crashed. Internet was lost and i couldn’t ping anything not even gateway
Here’s export
/interface bridge add ether-type=0x88a8 fast-forward=no name=ONEBRIDGE vlan-filtering=yes
/interface vlan add interface=ONEBRIDGE name=Intrerface-vlan20 vlan-id=20
/interface vlan add interface=ONEBRIDGE name=Intrerface-vlan30 vlan-id=30
dentity=""
profile=iot ssid=IOT_SH_158 vlan-id=20 vlan-mode=use-tag wds-cost-range=0 wds-defa
/interface bridge port add bridge=ONEBRIDGE frame-types=admit-only-untagged-and-priority-tagged interface=wlan2 pvid=20
/interface bridge port add bridge=ONEBRIDGE frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=30
/interface bridge port add bridge=ONEBRIDGE frame-types=admit-only-untagged-and-priority-tagged interface=ether3
/interface bridge port add bridge=ONEBRIDGE frame-types=admit-only-untagged-and-priority-tagged interface=ether2
/interface bridge port add bridge=ONEBRIDGE ingress-filtering=yes interface=ether1
/interface bridge port add bridge=ONEBRIDGE frame-types=admit-only-untagged-and-priority-tagged interface=wlan1
/interface bridge vlan add bridge=ONEBRIDGE tagged=ether1,ONEBRIDGE untagged=wlan2 vlan-ids=20
/interface bridge vlan add bridge=ONEBRIDGE tagged=ether1 untagged=wlan1,ether2,ether3 vlan-ids=1
/interface bridge vlan add bridge=ONEBRIDGE tagged=ether1,ONEBRIDGE untagged=ether4 vlan-ids=30
