15:49:56 system, info address list entry removed by admin
I had the same issue, but not found any solution to filter the logs. But I found the solution that we can use inside the script.
# Disable Logging so each add and remove isn't in the system log, we turn it back on at the end
:log debug "Disabling system Logging";
/system logging disable
.... {your code here} ....
# Enable the Logging
:log debug "Enabling system logging";
/system logging enable
You could try this, but it may hide other system log messages you still want. In a nutshell edit the default ‘info’ topic and add an additional topic ‘system’ but in this case, negate it so that it ignores all info-system messages.
Check the number of the logging item, to make sure you are editing the correct one.
/system logging
set 0 action=memory topics=info,!system
