For setting of supported-rates of CAPsMAN
Hello, everyone.
CAP centrally manage and I’d like to but at CAPsMAN, was in the normal /interface wireless,
but I do not see the item of supported-rates, or will not be set when it is under the control of CAPsMAN?
In the case of Japan, I’m often on the relationship you are installing multiple access points in a narrow place,
because often you want to fixed such as to 54Mbps in the supported-rates.
Regards.
