Force 10Mbit?
How to force 10Mbit on LAN interface? The card is 3Com 3C905B 100BaseTX (Cyclone) rev: 0. This may be 100BaseTX card but it should allow to be forced to run on 10Mbit…
When I enter interface ethernet and set that if to speed 10Mbps, and turn auto-negotiation off, the if stays on 100Mbps and by the monitor, the auto negotiation is still on…
Is there a way to force it…
Because we’ve used a bit longer UTP cable with no shield and plus it is going straight with 220V cable and…
Thanks!
Dakky21,
You can try changing the setting through the terminal…
/interface ethernet edit [/find name=LAN] speed=10Mbps
Just change “LAN” to the name of your interface.
Matt
