Force client over specific WAN on PPC load balancing
I have PPC load balancing setup on my mikrotik with 2 DSL modems. One of the client PC’s 192.168.2.52 needs to go over connection “ISP1”
I am attaching my export below and hope that someone can help me out.
# mar/13/2014 18:07:59 by RouterOS 6.9
# software id = 8I1D-X0J9
add l2mtu=1598 name=BRIDGE
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=\
    20/40mhz-ht-above country="south africa" disabled=no distance=indoors \
    l2mtu=2290 mode=ap-bridge ssid=Macaulay wireless-protocol=802.11
set [ find default-name=ether1 ] name=ISP1
set [ find default-name=ether2 ] name=ISP2
set [ find default-name=ether3 ] name=LAN
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
    tkip,aes-ccm mode=dynamic-keys unicast-ciphers=tkip,aes-ccm \
    wpa-pre-shared-key=***** wpa2-pre-shared-key=*****
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
    mac-cookie-timeout=3d
add name=dhcp_pool1 ranges=192.168.2.100-192.168.2.254
add address-pool=dhcp_pool1 disabled=no interface=BRIDGE name=dhcp1
add bridge=BRIDGE interface=LAN
add bridge=BRIDGE interface=wlan1
add address=192.168.2.1/24 interface=BRIDGE network=192.168.2.0
add address=192.168.1.21/24 interface=ISP2 network=192.168.1.0
add address=192.168.3.11/24 interface=ISP1 network=192.168.3.0
add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.2.1
set allow-remote-requests=yes servers=8.8.8.8
/ip firewall mangle
add chain=prerouting dst-address=192.168.3.0/24 in-interface=BRIDGE
add chain=prerouting dst-address=192.168.1.0/24 in-interface=BRIDGE
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=ISP1 new-connection-mark=ISP1_conn
    in-interface=ISP2 new-connection-mark=ISP2_conn
    dst-address-type=!local in-interface=BRIDGE new-connection-mark=ISP1_conn \
    per-connection-classifier=both-addresses:2/0
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
    in-interface=BRIDGE new-routing-mark=to_ISP1
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
    in-interface=BRIDGE new-routing-mark=to_ISP2
add action=mark-routing chain=output connection-mark=ISP1_conn \
add action=mark-routing chain=output connection-mark=ISP2_conn \
    dst-address-type=!local in-interface=BRIDGE new-connection-mark=ISP2_conn \
    per-connection-classifier=both-addresses:2/1
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add check-gateway=ping distance=1 gateway=192.168.3.1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=192.168.1.1
/ip upnp
set allow-disable-external-interface=no
/system clock
set time-zone-name=Africa/Johannesburg
/system leds
set 0 interface=wlan1
/system ntp client
set enabled=yes primary-ntp=159.148.60.2
I think so…
/ip firewall address-list
add list=stat-isp1 address=192.168.2.52
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Mark STATIC route to ISP1" dst-address-type=!local in-interface=BRIDGE new-routing-mark=to_ISP1 src-address-list=stat-isp1
Move this mangle-rule to the top.
Working perfectly! Thank you so much for your help. Brilliant little device this!
I try this and it works but I don’t understand why :smiley: You suggest to move it at the top but why it works also at the end? I would like to understand and not just copy/paste.
[admin@MikroTik] > /ip firewall mangle print
 0  D ;;; special dummy rule to show fasttrack counters
      chain=prerouting
 1  D ;;; special dummy rule to show fasttrack counters
      chain=forward
 2  D ;;; special dummy rule to show fasttrack counters
      chain=postrouting
 3    chain=input action=mark-connection new-connection-mark=WAN1_conn in-interface=ether1
 4    chain=input action=mark-connection new-connection-mark=WAN2_conn in-interface=ether5
 5    chain=output action=mark-routing new-routing-mark=to_WAN1 connection-mark=WAN1_conn
 6    chain=output action=mark-routing new-routing-mark=to_WAN2 connection-mark=WAN2_conn
 7    chain=prerouting action=accept dst-address=192.168.1.0/24 in-interface=bridge
 8    chain=prerouting action=accept dst-address=192.168.0.0/24 in-interface=bridge
 9    chain=prerouting action=mark-connection new-connection-mark=WAN1_conn passthrough=yes dst-address-type=!local in-interface=bridg>
      per-connection-classifier=both-addresses-and-ports:2/0
10    chain=prerouting action=mark-connection new-connection-mark=WAN2_conn passthrough=yes dst-address-type=!local in-interface=bridg>
      per-connection-classifier=both-addresses-and-ports:2/1
11    chain=prerouting action=mark-routing new-routing-mark=to_WAN1 connection-mark=WAN1_conn in-interface=bridge
12    chain=prerouting action=mark-routing new-routing-mark=to_WAN2 connection-mark=WAN2_conn in-interface=bridge
13    ;;; Mark STATIC route to WAN2
      chain=prerouting action=mark-routing new-routing-mark=to_WAN2 dst-address-type=!local src-address-list=stat-wan2
      in-interface=bridge
[admin@MikroTik] >
