Force Default Load of Custom Configuration Issue
In short, i’m trying to load a custom RSC configuration into a Microtik Router
However after loading it in on the restart with:
/system reset-configuration no-defaults=yes run-after-reset=flash/vpn-regional-example.1.0.rsc
I am no longer able to connect to the router, it just continuously says “Verifying and Connecting”
Is anyone able to see any issue in the following:
# jun/29/2017 22:39:38 by RouterOS 6.34.4
# software id = NNIT-8400
add auto-mac=yes comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
country=australia disabled=no distance=indoors frequency=auto mode=\
ap-bridge ssid=Example wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40mhz-Ce \
ap-bridge ssid=Example-5GHz wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
set bridge comment=defconf
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=myPassword123 \
wpa2-pre-shared-key=myPassword123
#/ip hotspot profile
#set [ find default=yes ] html-directory=flash/hotspot
add name=dhcp ranges=192.168.89.10-192.168.89.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add name=ovpn use-encryption=yes
/interface ovpn-client
add certificate=vpn_key.pem_0 cipher=aes256 connect-to=vpn.example.org.au \
name=vpn.example.org.au password=\
PNqilt66P5RKoXbPpazq port=443 profile=ovpn user=vpn-regional-example
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.89.1/24 comment=defconf interface=ether2-master network=\
192.168.89.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1
add address=192.168.89.0/24 comment=defconf gateway=192.168.89.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.89.1 name=router
add chain=input comment="defconf: accept ICMP" protocol=icmp
add chain=input comment="defconf: accept establieshed,related" \
add chain=input dst-port=22 log=yes log-prefix="remote-mgmt " protocol=tcp \
src-address=X.X.X.X
src-address=X.X.X.X
src-address=X.X.X.X
src-address=X.X.X.X
src-address=X.X.X.X
src-address=X.X.X.X
add action=drop chain=input comment="defconf: drop all from WAN" \
in-interface=ether1
add chain=forward comment="defconf: accept established,related" \
connection-state=invalid
"defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat log=yes out-interface=vpn.example.org.au
out-interface=ether1
/system clock
set time-zone-name=Australia/Brisbane
/system identity
set name=vpn-regional-rockham
/system ntp client
set enabled=yes primary-ntp=X.X.X.X secondary-ntp=X.X.X.X
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=vpn.example.org.au
It reboots with the correct SSID of Example
