I’m using a MikroTik DHCP server, and want to send DHCP option 43 to all clients, even those that did not request it in their Parameter-Request option. I’m trying to send “ANDROID_METERED” to clients to indicate to them that this hotspot is uplinked via 3G. Although Androids will act on a DHCP offer containing “ANDROID_METERED” in option 43 (the AP is set as a “mobile hotspot” under data usage from v4.0), they do not request it.
Is there any way to do this? The documentation http://wiki.mikrotik.com/wiki/Manual:IP/DHCP_Server#DHCP_Options suggests pretty clearly that…
According to the DHCP protocol, a parameter is returned to the DHCP client only if it requests this parameter, specifying the respective code in DHCP request Parameter-List (code 55) attribute. If the code is not included in Parameter-List attribute, DHCP server will not send it to the DHCP client.
…but I’m hoping there is some way around this.
Thanks.
