force firewall connection timeout
I looked all over for a solution to this, its not a huge deal, but I would like to know for future reference…
In my firewall “connections” I have all my connections and they count down if they are not being used. Some of them have a timeout of 120:00:00
Is there a way to force a timeout on these? I removed a PC from the network that had a bug…its still counting down 2 days later…
I want to force it out so when I plug the PC back in I can verify quickly that it does not come back. thanks!!
Did you try
/ip firewall connection
print
remove <num-of-connection>
–Tom
