Force Google DNS Usage
There are various posts which show how to intercept all DNS queries and redirect them, such as this- http://forum.mikrotik.com/t/force-users-to-use-specific-dns-server/129788/1
But, none of these codes seem to work. I have my DHCP server set to serve 8.8.8.8 as the DNS server, but I want to also add a rule to Mikrotik to intercept any non-8.8.8.8 queries and redirect them to 8.8.8.8. Does anyone have code for this?
It is not clear from the description, do you want to:
  1. Redirect all dns queries to the router and use 8.8.8.8 as an upstream dns for it.
  2. Redirect all dns queries to 8.8.8.8 and also use 8.8.8.8 for the router itself too?
  1. Redirect all dns queries to 8.8.8.8 and also use 8.8.8.8 for the router itself too?
The it will be something like this:
add chain=dstnat action=dst-nat dst-address=!8.8.8.8 to-addresses=8.8.8.8 protocol=tcp dst-port=53 in-interface=***YOUR_LAN_BRIDGE***
add chain=dstnat action=dst-nat dst-address=!8.8.8.8 to-addresses=8.8.8.8 protocol=udp dst-port=53 in-interface=***YOUR_LAN_BRIDGE***
The dst-address=!8.8.8.8 part is not really needed, it will work the same way without it, so I added it mainly to make the picture more clear.
Then specify 8.8.8.8 for the router itself in IP → DNS.
Sounds like some destination nat rules are in order…
add action=redirect chain=dstnat comment=
“Force Users to Router for DNS - TCP” dst-port=53 protocol=tcp
src-address-list=“whatever networks or interfaces or IPs you have identified in source address list”
“Force Users to Router for DNS - UDP” dst-port=53 protocol=udp
Hmm a little slow and a little different but I am using redirect rules, but believe both approaches should work..
In my case for each of the networks under DHCP server i would put the LANIP of the network for DNS.
for example
dns-server=192.168.1.1 for that network
192.168.2.1 for another
192.168.3.1 for another etc…
In that regard you are clearly stating each subnet should use the router DNS setting.
In the router DNS setting state 8.8.8.8 (although I prefer cloudfare 1.1.1.1 or 1.0.0.1) and
there are two pieces I am not sure of.
(1) Allow or not to allow remote requests? Answer is YES, this allows the ROuter to act as a DNS server.
(2) Requirement for input rules?
What I am not sure about is whether one needs to allow users to access port 53 on the input chain for the above setup???
I believe the answer is yes… FOr all services that the router provides, one has to allow access to that service.
add action=accept chain=input comment=“Allow LAN DNS queries-UDP” dst-port=53
in-interface-list=LAN protocol=udp
add action=accept chain=input comment=“Allow LAN DNS queries - TCP” dst-port=
53 in-interface-list=LAN protocol=tcp
Lastly, one needs one of two things on the input chain to close off this DNS.
a. a last rule in the input chain that says DROP ALL ELSE
b. if you dont use a, then you will need two INPUT chain rules blocking DNS from the WAN side
c. forget b and implement a, LOL.
d. For 20 million rupees, C is the right answer.
