ck900
March 22, 2016, 9:54am
1
i wanna force my hotspot users to use a differnt DNS server (OpenDNS).
The other devices should use the “normal” configured DNS.
I had this setup a while before but i cant find the instructions anymore.
Maybe someone have an idea?
greets from austria
You can set up a simple nat rule to re direct all the dns requests from the hotspot to the open dns server.
/ip firewall nat add chain=dstnat src-address=hotspotsubnet protocol=udp dst-port=53 action=dstnat to-address=opendns ip
This will re direct all dns requests to the opendns server
ck900
March 23, 2016, 9:53pm
3
thx @p3rad0x
but… it didn’t work
i setup the rule here: (for testing also tcp)
8 chain=dstnat action=dst-nat to-addresses=208.67.222.222 protocol=udp
src-address=10.5.50.0/24 dst-port=53 log=no log-prefix=""
9 chain=dstnat action=dst-nat to-addresses=208.67.222.222 protocol=tcp
any ideas?
ck900
March 25, 2016, 8:52pm
4
no ideas anyone?
i tried around and now it seems to work:
if i set de “default” dns server (ip\dns) to OpenDNS and the apply the rule for my local network (to use google dns for example) it will work
but the otherway will not work ?!
I have the same problem.
The script is:
add action=dst-nat chain=dstnat dst-port=53 protocol=udp src-address=
192.168.99.0/24 to-addresses=208.67.220.123 comment=“hotspot network”
add action=dst-nat chain=dstnat dst-port=53 in-interface=hs-bridge protocol=
udp to-addresses=208.67.222.222 comment=“hotspot bridge”
add action=dst-nat chain=dstnat dst-port=53 in-interface=LAN protocol=udp
to-addresses=8.8.8.8 comment=“lan bridge”
Why this works for some minutes and after this , stop to works?
