I have a network topo as follow:
I want Computer 01 go outside throught ISP 02:
- On Fortigate: I set policy to force IP Computer 01 (192.168.1.5/24) go outside throught Wan 1 Fortigate (192.168.0.2/24). It’s OK.
- But on Mikrotik, I don’t know how to config that IP force to outside throught ISP 02 ???
Please help me. Thank you.
Hey
I hope you don’t perform natting on fortigate?
If not you can route-mark (table:chain → mangle:prerouting) all packets from “computer 01” ip’s with mark for WAN02.
Thank for your reply.
Can you explain more? Thank you.
To do PCC you need to do mangling, and assign route-marks to packets (part of some connection) to always send them some particular route.
To force packets from an ip some route, you have to “hard-code” the routing-mark assignment to the one of wan2.
in this case, something like:
# all packets from comp01, not for internal network need to go over wan2
/ip firewall mangle add action=mark-outing chain=prerouting src-address=192.168.1.5 dst-address-type=!local new-routing-mark=<wan2 mark> ...
Note: the above rule needs to be executed before the usual PCC mangle logic
“/export hide-sensitive” would help
I work in mikrotik! I think he is using nat on fortigate! Because he is on dual wan (or sd-wan)!
This is my config on Mikrotik
add comment=LAN name=bridge1-LAN
set [ find default-name=ether1 ] comment=WAN1-7Mbps speed=100Mbps
set [ find default-name=ether2 ] comment=WAN2-3Mbps speed=100Mbps
set [ find default-name=ether3 ] comment=bridge1-LAN speed=100Mbps
set [ find default-name=ether4 ] comment=bridge1-LAN speed=100Mbps
add bridge=bridge1-LAN hw=no interface=ether3
add bridge=bridge1-LAN hw=no interface=ether4
add address=10.1.1.2/30 interface=ether1 network=10.1.1.0
add address=10.2.2.2/30 interface=ether2 network=10.2.2.0
add address=192.168.0.1/24 interface=bridge1-LAN network=192.168.0.0
/ip firewall address-list
add address=192.168.1.5 list=goSpecialWAN
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=yes in-interface=ether1 new-connection-mark=mark01 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark disabled=yes in-interface=ether2 new-connection-mark=mark02 passthrough=yes
add action=mark-connection chain=input connection-mark=no-mark disabled=yes in-interface=ether1 new-connection-mark=mark01 passthrough=no
add action=mark-connection chain=input connection-mark=no-mark disabled=yes in-interface=ether2 new-connection-mark=mark02 passthrough=no
add action=mark-routing chain=output connection-mark=mark01 disabled=yes new-routing-mark=route01 out-interface=ether1 passthrough=no
add action=mark-routing chain=output connection-mark=mark02 disabled=yes new-routing-mark=route02 out-interface=ether2 passthrough=no
add action=accept chain=prerouting dst-address=192.168.0.0/24 in-interface=bridge1-LANadd action=mark-routing chain=prerouting dst-address-type=!local in-interface=bridge1-LAN new-routing-mark=go_WAN2 passthrough=no src-address-list=goSpecialWAN
add action=accept chain=prerouting dst-address=10.1.1.0/30 in-interface=bridge1-LAN
add action=accept chain=prerouting dst-address=10.2.2.0/30 in-interface=bridge1-LAN
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge1-LAN new-connection-mark=mark01 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/0
add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface=bridge1-LAN new-connection-mark=mark02 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/1
add action=mark-routing chain=prerouting connection-mark=mark01 in-interface=bridge1-LAN new-routing-mark=route01 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=mark02 in-interface=bridge1-LAN new-routing-mark=route02 passthrough=yes
add action=mark-routing chain=output connection-mark=mark01 new-routing-mark=route01 passthrough=yes
add action=mark-routing chain=output connection-mark=mark02 new-routing-mark=route02 passthrough=yes
add action=mark-routing chain=prerouting disabled=yes new-routing-mark=go_WAN1 passthrough=yes src-address-list=goWAN2
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether1 new-connection-mark=mark01 passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=ether2 new-connection-mark=mark02 passthrough=yes
add action=masquerade chain=srcnat out-interface=ether2
add check-gateway=ping distance=5 gateway=10.1.1.1 routing-mark=route01
add check-gateway=ping distance=5 gateway=10.2.2.1 routing-mark=route02
add distance=1 gateway=10.1.1.1 routing-mark=go_WAN2
add distance=1 gateway=10.2.2.2 routing-mark=go_WAN1
add check-gateway=ping distance=10 gateway=10.2.2.1
Under “/ip route” I don’t see any entries for “192.168.1.0/24”, which would corroborate the fact that’s not a routed network, and most likely natted.
Can you disable natting for that link in fortigate?
Hi everyone
I have the same problem, could you find any solution?
My Network Schematic is same as yours, the only difference is, I don’t use PCC for load balancing.
My mikrotik routerboard is 1100AHX2 and Fortigate is 201E in the Nat/Router mode.
Are you have any solution for my problem?
