Hi
I have two WAN connections on my router board RB1036, the configuration is failover.
what I need is to force spceific IP to use the second connection whatever the circumstances are.
that IP is consuming more than 100MB/s. whenever I use these configurations below, the client (that forced to use the second connection) is suffering a lot from latency and slow internet speed.
/ip firewall mangle add chain=prerouting src-address=192.168.1.10 \
dst-address=!192.168.1.0/24 action=mark-routing new-routing-mark=wan2
/ip firewall nat add chain=srcnat routing-mark=wan2 action=src-nat \
to-addresses=2.2.2.20
/ip route add dst-address=0.0.0.0/0 gateway=2.2.2.2 routing-mark=wan2
the second connection is fine I thought at the beggening that there was an issue with it.
is there any better idea to force routing without internet problems?
thnaks in advance
