Force SFP interface running
Hello all,
I am using RB4011iGS with current ROS 6.48.1 along with some GPON ONU modules,
and noticed that SFP interface activates only when FTTH fiber is actually connected (which makes sense on standard tranceivers).
However most ONUs (nokia G-010S-A, ZTEs, … as examples) always expose an internal ethernet/IP interface, even when physical GPON is disconnected, and some do -only- when GPON link is down.
Is it possible to configure /interface ethernet or associated /ip address to disable opt PHY running check and activate interface as long as SFP module is up ?
Thanks.
I don’t think MT actually supports ONU SFPs in any way. If it works somehow it’s purely coincidental. So I wouldn’t hold my breath waiting for your suggestion to be implemented. Besides, if you really want your suggestion to get to MT devs, you’ll have to communicate it directly, this forum is user forum not official support platform.
I have same problem(
