Hello everybody,
I’m trying to get a RB3011 running with a special Technica Engineering 100BASE-T1 SFP module.
https://technica-engineering.de/en/produkt/100base-t1-sfp-module/
Auto negotiation has to be disabled for the SFP port to get into a running state.
The problem is that the link synchronizes to 1 Gbps rate no matter what settings are set for the interface. The module doesn’t seem to work properly with this sync state and instead the speed/rate needs to be forcefully reduced to 100 Mbps. But since no settings are impacting the displayed rate of 1 Gbps Full Duplex, this combination may not be working.
Is there any known limitation or situation with the RB3011 or RouterOS where a set SFP speed is not applied?
