Force SMTP through specific gateway
my setup contains 4 different internet provider. One provider is for usual traffic like browsing and downloading. Another one is for sending/receiving emails. I want all traffic of a specific dst.address to go through a specific gateway but I can’t find any ruleset which allows me to do this.
I’ve allready read http://wiki.mikrotik.com/wiki/Policy_Routing_in_RouterOS_2.9.x
Short:
eth1 = LAN
eth6 = VDSL
eth7 = SDSL
I’ve created a gateway 0.0.0.0/0 to use eth6 for all traffic. Now I want the traffic to 176.12.12.12 (f.e) to use eth7 for outbound. I was using pfSense till now and all I did was creating a firewall for dst.address 176.12.12.12 and ticking “use gateway blahblah” in extra options. That’s it. So how to implement this with ROS?
Best Regards,
Dominik
Accodring to your referenced wiki article I’d do it like this:
/ip firewall mangle add chain=prerouting dst-address=176.12.12.12/32 action=mark-routing new-routing-mark=example passthrough=yes comment="" disabled=no
/ip route add gateway=<gateway from mail-ISP> routing-mark=example disabled=no
/ip route rule add src-address=0.0.0.0/0 table=example action=lookup
-Chris
