I would like to configure an LtAP mini to function as a web proxy which is accessed via the ethernet port. I’d like web proxy requests to go via the LTE interface only, and any other internet requests to go via the ethernet port. When configuring the web proxy we can only set the source address of requests to somewhat control where they get proxied to. The ip address of the LTE interface is dynamic which makes this a little awkward as it would need to get updated every time it changes.
Is there a nice solution to this? I wondered if I could somehow have an isolated network containing only the LTE interface and a bridge, and set the source address in web proxy to a local IP that would use NAT to go via whatever address the LTE interface was currently using, but I’m not sure that’s possible because the LTE interface doesn’t seem to work like an ethernet interface.
I was able to get the behaviour I wanted by manually setting the web proxy source address to the LTE ip address and creating a static route to a specific IP, i.e.
add disabled=no dst-address=172.67.168.106 gateway=lte1 routing-table=main suppress-hw-offload=no
but that’s not going to work in the general case.
I’ve attached the basic config I have at the moment.
ltap-config.txt (6.6 KB)
