Forced routing issue
I have one router (network gateway) with two public interfaces.
WAN1 has /24 range of public addresses of ISP 1
WAN2 has one /24 public address of adsl ISP2
One LAN interface connects (with routing tables) to all my LAN networks.
To test port forwarding for incoming traffic via ISP1 network I want to route my LAN residing PC out via ISP2
I have policy routing where via addrs-list local clients get either a routing mark to route to ISP1 connected interface or they get a routing mark to route to ISP2 connected interface. Also a default route set to use ISP2.
I can now simply switch my PC to use either ISP1 or ISP2. Just give him an other address listing and after some time (secs) the new routing mark arranged this PC to go to the internet via chosen ISP. Works like a charm.
My problem is now, if I want to traceroute a public IP of ISP1 that resides on the WAN1 interface of my network gateway the traceroute shows that traffic hits that IP immediately. After some LAN routers it shows immediately the public IP of the network gateway! Not even the LAN IP of that network gateway!
Any other traceroute to an external IP on the internet shows the LAN IP of the network gateway and any next router down the road…
In my mangle I even created a rule that traffic from my lan with destination the public IP of the network gateway is forced to go out to the interface that is connected to ISP2. This way my expectation is that the ping packet enters the internet via ISP2 and than search and finds the route to an ISP1 connected users. (me). This should show a loop over the internet back to my network gateway.
But since the public IP is on the router itself that also have to send the ping out to WAN2 it looks like the router is so intelligent it replies to the ping since it knows the WAN1 owns that IP. Even if I tell router to send the package out WAN2 first. This just doesn’t happen now…
Any suggestions?
It basically has to do with the routing table.
The most specific route will prevail over other routes for the same destination.
Since the IP you are trying to trace is assigned to your interface, it will
create a dynamic route, which is more specific than other you may try
to create using mangle.
Why it doesn’t happens anymore, i don’t know. What changed since it doesn’t?
Take a look at your routing table and see the rules which would point to that IP.
Caci99 is spot on. The problem is that the directly connected route is more specific that the route you currently have, which is presumably a default route. The routing table will always choose the most specific route for a destination it can find. That’s how fundamental TCP/IP routing works.
You can override that by inserting a route for the /32 public IP on interface 1 and refer to the routing mark, and assign a next hop of ISP 2. Now that route will be even more specific and will be chosen for traffic to that public IP, but only if the routing mark also matches.
OK guys, that seems to make some sense. I presume with “more specific” you mean the distance for dynamically created routes is “0” where my policy routes are at least “1”?
Ok, the dynamically route for the public IP is reading:
#          DST-ADDRESS        PREF-SRC     GATEWAY            DISTANCE
15 ADC  **.***.92.0/24     **.***.92.2     WAN1                      0
How do I now make a more specific route for the specific Ip to go to another gateway?
I made this:
 2 A S  **.***.92.111/32                   WAN2                      1
It has as extra argument the routing mark “WAN2” (The routing mark parameter doesn’t print with the print command!)
I also have route rule set:
1   ;;; For testing ******* external access.
     dst-address=**.***.92.111/32 interface=LAN action=lookup table=WAN2
In mangle rule is set:
 0   chain=prerouting action=mark-routing new-routing-mark=WAN2 passthrough=no dst-address=**.***.92.111 in-interface=LAN
This rule is the top one, so this traffic should get marked and leave the chain.
It is still not working… :frowning:
ok fewi, I haven’t taken all your words in advice yet.
You talk about assigning a next hop?
How to do that? I haven’t got a glue. I see a “Nexthop” tab in winbox, but to be honest never used that at all… can you show me how?
You probably can’t assign “WAN2” as a gateway as it’s presumably not a point to point interface. You need to assign as a gateway the IP address of the ISP router on that network. The directly connected route shows that because it’s a directly connected route, which the specific /32 route is not.
If you need specific help please post the output of “/ip route print detail”, “/ip address print detail”, and “/interface print detail”.
If you feel like you need to edit public IPs because your routers are insufficiently hardened against attacks (on a side note you should then also consider hardening your routers so they aren’t vulnerable to attacks) please find/replace the first two octets with two other consistent numbers. Asterisks and x’s make things hard to read. Turning 192.168.1.1 into 16.16.1.1 obfuscates just as well but is consistent and easy to read.
Next hop is just another word for gateway. The gateway of the specific route has to be an IP address. You won’t need that route rule.
Ok, I changed the second code part (for the specific route) into following:
2 A S  **.***.92.111/32              10.10.20.1              1
so made the gateway specific. Still not working…
See my previous post.
If you need specific help please post the output of "/ip route print detail", "/ip address print detail", and "/interface print detail".
How much text do you want. I have 18 routes, 7 route rules, 259 IP addresses and 4 interfaces. You want all that info?
You’re right. But to change all the info you’d requested takes me some hours into the night!. I am happy to send them to you by mail, I trust you. :sunglasses:
But does it harm? Or should I remove it?
Sure. I’d always rather have too much info than too little.
You’re right. But to change all the info you’d requested takes me some hours into the night!. I am happy to send them to you by mail, I trust you. 8)
Presumably your public IPs (the only ones that need obfuscating) are only on a few prefixes. Let’s say they all start with 210.34. Gather all that information, paste it into notepad, edit > replace… and find “210.34” and replace it with “2.2”. Then paste THAT result here. Takes all but a minute, even if there’s 5 or 6 prefixes to edit.
I’ve tried explaining it in the abstract but apparently that isn’t working, so the only way I can help you is if you post specific information from your router so I can write the configuration changes for you.
OK, I am going to do this tomorrow. I have to put it down in such a way it all makes sense. It’s now way too late in the night to do this…
I don’t think this is going to work. The routing table will check who has the shortest distance first.
Actually I don’t know of any solution to overcome the automatic routing with distance=0
Still, a /32 is more specific than e.g. a /29.
So a /32 route with metric 100 will always win against a /29 route with metric 0.
Hmm, I tested and you are right. My mistake :slight_smile:.
I checked a little in the wiki to see if there is any documentation to refresh my memory,
about how routes are selected. And I found this:
Criteria for selecting candidate routes
To participate in route selection process, route has to meet following criteria:
route is not disabled.
distance is not 255. Routes that are rejected by route filter have distance value of 255.
pref-src is either not set or is a valid local address of the router.
routing-mark is either not set or is referred by firewall or policy routing rules.
If type of route is unicast and it is not a connected route, it must have at least one reachable nexthop.
http://wiki.mikrotik.com/wiki/Manual:IP/Route#Criteria_for_selecting_candidate_routes
SInce the route in discussion is a connected route, does this mean that it will always prevail over others?
I can’t say I’ve tried mostly because when I need to test something like Rudy has to I just use an outside machine or a 3G modem or something.
But if you look at the PCC wiki example there are explicit rules to prevent policy routing from messing up the path of packets going to directly connected networks, so it should conversely also be possible to force that issue. Other routing platforms can certainly do this, but i have never tried on a Linux based one.
Ok, it took some time but I have the info fewi asked for.
Its edited a bit and some clarifications are made.
I made it in a word document as attachment.
If this is not working, I can copy and past it directly in this topic. It is only some 3 pages long…
Could you do a text file, pretty please? I’ll be spending most of my day on devices that don’t read Word documents.
well, here it is. but now most of my editing is gone down the drain… Its a bit more messy to read and coloured markings are gone…
Some info about network and main gateway router.txt (54.6 KB)
in .pdf
This at least is readable in original format and with coloured remarks etc..
Some info about network and main gateway router.pdf (68.8 KB)
Remove all those route rules for this ping test that could affect the packets you’re testing with. They are interfering.
Your gateway on the WAN2 interface is 10.10.20.1.
If you want test traffic to 1.1.1.1 through WAN2, mark the traffic with some route mark, e.g ‘route-test’. Then add a route like this:
/ip route add dst-address=1.1.1.1/32 routing-mark=route-test gateway=10.10.20.1
Now, don’t take the next bit personally: you’re making this way, way, way too complicated. This is a very simple question, the only reason I ever asked for those exports was because you didn’t seem to immediately get my generic explanation, and I wanted to give a specific example for your specific network. There was no need to mark anything in color. I didn’t need to read a nicely formatted document on how your network is run, I just wanted some IP addresses to use in examples, and I wanted them in text form. Even if I could have opened a Word document I would have just copied and pasted everything into my favorite text editor - see below for why.
Unfortunately you didn’t seem to follow my advice to run find/replace on the entire document because it still contains your public IP addresses in the comments and mangle rules (at least, might be in more places), which is why I ended up NOT using an IP from your network in my code above. You may want to remove those documents if it worries you.
You also ended up not even showing the output from the commands I asked for: I asked for “/ip route print detail”, for example, and you showed the output from “/ip route print”. There’s a huge difference between the two: only detail shows routing marks, for example. It’s also formatted nicely for be parsed by computers. I have scripts I shoot the output from these commands through that removes unimportant bits and formats things nicely for me to read. That’s why I want text format. I don’t care if it’s messy to read, I’m used to CLI output.
Now, that said, I do appreciate all your effort - it was just unnecessary to spend all that time. It would have been absolutely sufficient to paste the commands I asked for into a CLI, right click > select all > copy > paste > find/replace on the first two octets of IPs if you’re worried about posting them. 2 minutes, tops.
But, to come back around to the topic at hand: don’t use route rules (or figure out how to do this with route rules, I don’t use those) and remove all of the ones that could apply to the packets in the (TCP/IP) connection you’re testing. Make a mangle rule that applies the route mark to the traffic you want to test. Make a route with a default distance for the /32 you’re testing, refer to the routing mark, and set the gateway of that route to the ISP next hop you want the packet to go through - for your WAN2 interface that appears to be 10.10.20.1.
I sincerely hope that helps, and explains how to approach this. Again, don’t take the side bar personally. I truly enjoy reading your posts on wireless topics.
