Forced routing with UTM connected both ends to Mikrotik
Hello everyone.
I need to force routing over a specific interfaces - as in the following (simplified) picture. Assume that between ether2 and ether3 there’s just a cable, and no addresses have been assigned so far. The goal is to have a UTM in bridge mode plugged in with WAN interface connected to ether2 and LAN to ether3.
I cannot just daisy-chain these devices, because real configuration is quite complicated with multiple VLANs (e.g. both Internet and LAN are tagged VLANs on the same wire). I can cope with that, it’s just I have no idea how to configure the router so that it push packets using non-quite-optimal path :slight_smile:
Any ideas? Thanks in advance!
Anyone, please?
If the UTM is in bridge mode, why not simply connect it in-line with one of the ethernet ports?
Maybe you should just make bridge for ETH1+ETH2 and the second for ETH3+ETH4 and connect it with this UTM?
Thanks, the traffic inside the wire that would be connected to the UTM is tagged VLANs and from what I know it doesn’t support VLANs (Sophos). And in real config there will be two UTMs daisy chained (client request), and I don’t even know what the second one is. So I assume it will not work. Or am I wrong?
Thanks. Sounds interesting. I assume some policy routing will still be required? I’ll check that and get back to you.
I configured up a pair of Sophos UTM 430s a couple of years ago. I configured VLANs. It wasn’t in transparent mode though. I don’t know if that makes a difference (I wouldn’t think so, but maybe).
To whoever may be interested - I just gave up and added another Mikrotik to the network. So the UTMs are in between two Mikrotik routers and it works like a charm.
The planned config would be just too problematic (even if it’s doable). With the second device it’s easy as 1, 2, 3.
Thanks to all who responded.
