wilburt
December 7, 2015, 12:18am
1
Hi experts,
I have two out interfaces to the WWW. What is the best way to push out bound traffic from a particular network out a specific gateway?
For example
Out Eth1 10.20.20.2
Out Eth2 172.15.12.2
Internal DHCP server
192.168.88.0/24
192.168.99.0/24
Looking to have 88 network out Eth1 and 99 network out Eth2
This is done via Policy Based Routing
Butch Evans has an excellent blog posting on this - http://blog.butchevans.com/2008/09/mikrotik-policy-routing-implementation-example/rather than me retyping all this stuff over.
If your US Based - I suggest checking out Butch’s Training Sessions as well.
Thanks heaps! i will read through
So far so good. I am able to ping, and get DNS but for some reason i can’t browse the internet.
THere are no firewall rules that are dropping packets.
I have static routes that point back and also NAT on that network and port.
any ideas where else could go wrong?
Thanks for the pointer. It works.
There is one flaw. How do we ensure that a specific network can only go out 1 ISP and not the other? The good, 192.168.88.0/24 and 10.11.0.0/20 can’t go out 172.16.1.0/24. However, Problem is 192.168.99.0/24 network can go out 10.10.10.0/24 ISP if 172.16.1.0/24 network is unreachable. This is what i have
add gateway=172.16.1.1 routing-mark=RTF
add gateway=10.10.10.1 routing-mark=WEFI
/ip route rule
add dst-address=192.168.88.0/24 action=lookup table=main
add dst-address=192.168.99.0/24 action=lookup table=main
add dst-address=10.11.0.0/20 action=lookup table=main
add dst-address=10.10.10.0/24 action=lookup table=main
add dst-address=172.16.1.0/24 action=lookup table=main
add src-address=10.10.10.0/24 action=lookup table=WEFI
add src-address=172.16.1.0/24 action=lookup table=RTF
add routing-mark=RTF action=lookup table=RTF
add routing-mark=WEFI action=lookup table=WEFI
/ip firewall mangle
add chain=prerouting src-address=192.168.99.0/24 action=mark-routing
new-routing-mark=RTF passthrough=no
add chain=prerouting src-address=192.168.88.0/24 action=mark-routing
new-routing-mark=WEFI passthrough=no
add chain=prerouting src-address=10.11.0.0/20 action=mark-routing
