Hello. i forgot my mikrotik 1100 admin password or somethink it happen i am not shure. but also i can’t access to telnet and also i don’t have console cable. i don’t have another user. what can i do? could you pls someone help me?
Reset the device.
Hello Jarda. thank you for support but if i resetting console all configuration is going also. and i cant configurate again because i dont have console cable
You can configure the device without console cable. Just plug ethernet cable and use winbox to connect over mac address.
if i give you a teamviewer sharing, can you do this for me ? because i dont have any idea about winbox. this is my first time for using a mikrotik.
Generally yes, put here your Skype nickname, I will contact you later. As newbie, start with reading the manual.
https://wiki.mikrotik.com/wiki/Manual:Winbox
I need similar help. skype help anyone?
