Dear guys,
I have forgot mikv2.9.51 router password.How can i recover it.Plz help me out.I dont want to reinstall as it is preconfigured…
thanks in advance…
Dear guys,
thanks in advance…
There is no other way to reset the password, just reinstall to reset all config.
thanx for reply…
i have the licence key . If i redownload the trial version of same OS and reinstall then can i use same licence key for the system…plz help in out…
use netinstall to reinstall your router - that way you will not alter your license, just erase the settings
