I need to connect to a remote network where a fortigate device is installed.
I would like to use my mikrotik router to connect to the fortigate device using an ssl-vpn connection.
I am not the administrator of the fortigate device, so I will need to get the assistance of the administrator on the remote side to assist
What would I use with the mikrotik router?
What settings would I need to get from the fortigate device to correspond to the mikrotik settings
I tried using SSTP, but I get an error… “terminating… - broken http connection”
I’m not sure if that’s possible. As far as I know, the SSL VPN service on FortiGate devices is pretty much SSTP, but it’s a proprietary version that is only compatible with FortiNet’s official client software and browser plugin. At least I’ve never seen support for third-party clients mentioned anywhere in the documentation for FortiGate firewalls. My experience with FortiNet products is not that extensive, though, so I might be wrong.
We use a FortiGate firewall with SSL VPN at work, so I can do a little bit of testing and will let you know if I figure out a way to make it work.
Any updates on this? I haven’t made any progress on the SSL VPN bit, but I can confirm that IPSec between a FortiGate and a RouterBoard works just fine. I have successfully set up a gateway-to-gateway IPSec VPN connection between our FortiGate at work and my RouterBoard at home. Let me know if you’d like to try that option, and I’ll provide detailed instructions on setting it up.
From the NET
QUOTE: " I have set up Fortigate VPNs with Cisco, Watchguard and Sonicwalls in the past without issue. As long as all the settings for Phase 1 and Phase 2 match it should work regardless of vendor." UNQUOTE
VPN IPSec between Fortigate and Mikrotik is quite easy. The only need is to match both phase1 and phase2. In fortigate side, you can choose interface mode instead of policy based vpn if you prefer
