Forum style for Mikrotik phpBB forum problem.
For some time now, I have used default board style (prosilver) for Mikrotik forum.
As of today this is gone and even if I select prosilver it uses canvas.
I do NOT like canvas, since I can not see on the icon to the left of a post if I have posted in the thread.
In prosilver it shows a small star in the logo for all thread you are posting in.
It seems to work in SE Square, but there are other problems.
Style "prosilver spesial edition" does not work at all.
So Mikrotik, please fix prosilver. Its the default and will not give you problem when upgrading forum.
To change board style:
Click your name->User Control Panel->Board Pregerenses->My board style.
For some reason prosilver seems to work now.
But I did get error when try to post message, so something is going on.
Here is message i get when posting on forum now:
[code:lk99u868]Fatal error: Uncaught exception ‘Symfony\Component\DependencyInjection\Exception\ServiceNotFoundException’ with message ‘You have requested a non-existent service "notification.method.board".’ in /www/forum.mikrotik.com/html_315/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/ContainerBuilder.php:802 Stack trace: #0 /www/forum.mikrotik.com/html_315/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/ContainerBuilder.php(444): Symfony\Component\DependencyInjection\ContainerBuilder->getDefinition(‘notification.me...’) #1 /www/forum.mikrotik.com/html_315/phpbb/notification/manager.php(907): Symfony\Component\DependencyInjection\ContainerBuilder->get(‘notification.me...’) #2 /www/forum.mikrotik.com/html_315/phpbb/notification/manager.php(899): phpbb\notification\manager->load_object(‘notification.me...’) #3 /www/forum.mikrotik.com/html_315/phpbb/notification/manager.php(461): phpbb\notification\manager->get_method_class(‘notification.me...’) #4 /www/forum.mikrotik.com/html_315/p in /www/forum.mikrotik.com/html_315/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/ContainerBuilder.php on line 802[/code:lk99u868]
Now the forum went back to canvas style again. :frowning:
Also the selection for board style under ucp is gone.
Please do use default style (prosilver), since canvas does not contain all functions. It may be outdated?
Also there are several function under UCP that are not working.
See photo, marked in red.
Just wait until DNS receives the updates, and also clear your cache.
Some old skins were not compatible with new PHPBB, so we disabled them. We will put them back if we find newer versions.
Ok
Why do not leave default style prosilver? Its good and is compatible with all phpBB version.
You need to find a style that shows where I have posted. I do not like to setup notification for every thread I monitor.
Monitor may be the problem whit slow post (10 second wait) here, since you can not see where you post, many add monitoring.
Yes. Bring back prosilver.
Resolved
