forward chain rules not being implied
Dear all,
I have the following setup : CCR-1016 v6.33 and a HP 2530 switch. I m trying to set up a proper firewall on the router for multiple vlan routing and nat as well.
On interface vlan20 there s a dhcp server, with the ip address 192.168.20.1
The switch has a fix ip address in vlan0 (192.168.0.11).
Now i have to users in vlan20(ip1: 192.168.20.60, ip2: 192.168.20.59), connected to the same HP switch, and i enabled intervlan communication:
  • chain=forward action=accept in-interface=vlan20 out-interface=vlan20
The problem is that the 2 device can actually communicate, but the bytes/packets counter is not being hit.
After noticing this , i tried to deny communication between the users in the forward chain for testing purposes, without luck.
-chain forward action=drop src-address=192.168.20.60 dst-address=192.168.20.59 log=yes
(placed this rule at the beginning of forward chain)
Looks like forward rules are not implied to them, they can communicate freely, and i can’t log any communication beetween them. I repeat the users are connected to the same switch.
I have two questions:
  1. They can communicate because of the switch maintains a mac-address table ?
  2. is it possible to apply forward deny rules to users in the same vlan connected to the same switch? (ex. a client isolation rule, which is my goal)
Any guidance would be much appreciated
Steve.
they communicate each other directly through switch, you can’t stop this in router.
device that connected to the same switch can communicate each other, nothing u can do about that
Of course you cannot solve this in the router, but it can be solved in the switch!
Switches like that have a port isolation feature.
Thanks for the correct answer, found this feature under the name of protected ports in case of the Hp switches.
