Forward Drop invalid | Broke my IP routing?
I need some clarification on this because it’s been a head scratcher for me for days as to why I couldn’t reach ANY subnets beyond a certain point in my network
Here’s a rough diagram
The whole network was running OSPF/MPLS up to Router E
Network addresses were advertised just fine, everything had the correct routing table
I couldn’t reach any subnet on F from A/B/C, I also couldn’t reach any IP address on router E other than IP addresses I put on the interface facing D
Traceroute didn’t go even 1 hop from router A/B/C, but D worked fine.I think this is due to MPLS
On router D I have a firewall filter rule that just says “action=drop chain=forward comment=“Preset: Drop Invalid” connection-state=invalid” as soon as I disable that rule, everything works fine and I can ping end to end. Why is this?
The counters ticking on this rule? If yes, check firewall filters rules with source addresses, static arp records and mangle rules. Put config here. Or maybe you’ll find a mistake by yourself :slight_smile:
If the official firewall manual is not clear, try reading my summary for newbies.
Yes. It was at that point where I was just throwing my arms up in the air thinking “this HAS to be a bug/feature” and trying random things
Here’s part of the config - the entire thing is much larger as router D serves multiple purposes. I’ve pruned what shouldn’t be relevant but left entries in related to both interfaces.
ether1 is the uplink to C, ether2 is the downlink to E, D and E should only really talk to each other on VLAN52, the native interface and VLAN200 are part of a legacy bridged network
172.16.201.10 is the loopback address
172.16.52.1 is router D on the D->E segment
172.16.52.2 is router E on the D->E segment
The above addresses are reachable
add comment="!! Need to remove later" name=TempBridge
add name="MPLS Loopback" protocol-mode=none
add name="Mgmt Bridge"
set [ find default-name=ether1 ] comment="Uplink to C"
set [ find default-name=ether2 ] comment="Downlink to E"
/interface pppoe-client
add disabled=no interface=PPPoE-Bridge max-mru=1500 max-mtu=1500 name=pppoe-WAN password=*** user=***
/interface vpls
add advertised-l2mtu=1516 disabled=no l2mtu=1516 mac-address=11:22:33:44:55:66 name="VPLS - Uplink" remote-peer=172.16.201.1 vpls-id=2:11
/interface vlan
add disabled=yes interface="VPLS - Uplink" name="VPLS.5 - Trusted PPPoE" vlan-id=5
add comment="Downlink Old Mgmt" interface=ether2 name="ether2.200 - Old Mgmt Network" vlan-id=200
add interface=ether2 name="ether2.52 - Downlink to E" vlan-id=52
add name=InternetFacing
add name=Management
add name=CommsN_Out
add name=HS-PPPoE
/routing ospf instance
set [ find default=yes ] metric-default=5 router-id=172.16.201.10
add bridge=TempBridge interface=ether2
add bridge=TempBridge interface=ether4
set enabled=yes
add interface=ether1 list=InternetFacing
add interface="ether2.200 - Old Mgmt Network" list=InternetFacing
add interface=pppoe-WAN list=InternetFacing
add address=172.16.201.10 interface="MPLS Loopback" network=172.16.201.10
add address=10.245.1.1/24 interface="Mgmt Bridge" network=10.245.1.0
add address=172.16.51.3/27 interface="ether2.200 - Old Mgmt Network" network=172.16.51.0
add address=172.16.52.1/27 interface="ether2.52 - Downlink to E" network=172.16.52.0
/ip dhcp-client
add default-route-distance=5 dhcp-options=hostname,clientid disabled=no interface=ether1
add add-default-route=no dhcp-options=hostname,clientid disabled=no interface=ether2
add action=accept chain=input comment="Preset: Established/Related" connection-state=established,related
add action=accept chain=forward comment="Preset: Established/Related" connection-state=established,related
add action=drop chain=forward comment="Prevent Office routing to Private IP ranges" dst-address-list=PrivateIPs in-interface=OfficeBridge
add action=drop chain=forward comment="Prevent Hotspot routing to Private IP ranges" dst-address-list=PrivateIPs in-interface=hs-bridge
add action=accept chain=input comment="Preset: Accept ICMP" protocol=icmp
add action=accept chain=input comment="Preset: Accept WinBox (Trusted IP's)" dst-port=8291 protocol=tcp src-address-list=Trusted
add action=accept chain=input comment="Preset: Accept WinBox (Mgmt)" dst-port=8291 in-interface-list=Management protocol=tcp
add action=accept chain=input comment="Routing Preset: BFD" dst-port=3784,3785 protocol=udp
add action=accept chain=input comment="Routing Preset: OSPF" protocol=ospf
add action=accept chain=input comment="Routing Preset: MPLS / LDP" dst-port=646,711 protocol=tcp
add action=accept chain=input comment="Routing Preset: MPLS / LDP" dst-port=646 protocol=udp
add action=accept chain=input comment="Routing Preset: BGP" disabled=yes dst-port=179 protocol=tcp
add action=drop chain=input comment="Preset: Drop outside DNS requests" dst-port=53 in-interface-list=InternetFacing protocol=udp
add action=drop chain=input comment="Preset: Drop Invalid" connection-state=invalid
add action=drop chain=forward comment="Preset: Drop Invalid" connection-state=invalid disabled=yes
add action=drop chain=input comment="Preset: Drop all from InternetFacing" in-interface-list=InternetFacing
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=drop chain=HS-PPPoE comment="Prevent HS PPPoE Clients routing to Private IP ranges" dst-address-list=PrivateIPs
/ip firewall mangle
add action=change-ttl chain=prerouting comment="Increase TTL for hotspot to hide '2' routers" in-interface=hs-bridge new-ttl=increment:2 passthrough=yes
add action=change-ttl chain=prerouting comment="Increase TTL for office to hide '3' routers" in-interface=OfficeBridge new-ttl=increment:3 passthrough=yes src-address-list=!PrivateIPs
add action=mark-connection chain=input comment="Mark incoming on CommsN" in-interface="ether2.200 - SME Mgmt Network" new-connection-mark=CommsN_in_c passthrough=yes
add action=mark-connection chain=input comment="Mark incoming on CommsB" in-interface=pppoe-WAN new-connection-mark=CommsB_in_c passthrough=yes
add action=mark-connection chain=prerouting comment="Mark Hotspot -> CommsN" dst-address-list=!PrivateIPs in-interface=hs-bridge new-connection-mark=CommsN_c passthrough=yes
add action=mark-connection chain=prerouting comment="Mark PPP Clients -> CommsN" in-interface-list=CommsN_Out new-connection-mark=CommsN_c passthrough=yes
add action=mark-connection chain=prerouting comment="Mark Office -> CommsB" in-interface=OfficeBridge new-connection-mark=CommsB_c passthrough=yes src-address-list=!PrivateIPs
add action=mark-packet chain=prerouting comment="Mark CommsN packets" connection-mark=CommsN_c new-packet-mark=CommsN_p passthrough=yes
add action=mark-packet chain=prerouting comment="Mark CommsB packets" connection-mark=CommsB_c new-packet-mark=CommsB_p passthrough=yes
add action=mark-routing chain=prerouting comment="Send out GCOM" in-interface-list=!InternetFacing new-routing-mark=GCOM packet-mark=CommsN_p passthrough=no
add action=mark-routing chain=prerouting comment="Send out metered WAN (CommsB)" in-interface-list=!InternetFacing new-routing-mark=HotelWAN packet-mark=CommsB_p passthrough=no
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=10.0.0.0/21 to-addresses=172.16.51.3
add action=masquerade chain=srcnat comment="Masquerade to DSLAM" dst-address=10.11.104.2
add action=masquerade chain=srcnat comment="Preset: Masquerade Management" src-address=10.245.1.0/24
add action=masquerade chain=srcnat comment="Preset: NAT out internet facing interfaces (non private)" dst-address-list=!PrivateIPs out-interface-list=InternetFacing
add action=dst-nat chain=dstnat comment="DstNat to DSLAM (from trusted IP's only)" dst-port=23 protocol=tcp src-address-list=Trusted to-addresses=10.11.104.2
/mpls interface
set [ find default=yes ] mpls-mtu=1538
/mpls ldp
set enabled=yes loop-detect=yes lsr-id=172.16.201.10 transport-address=172.16.201.10
/mpls ldp interface
add interface=ether1 transport-address=172.16.201.10
add interface="ether2.52 - Downlink to E" transport-address=172.16.201.10
/routing ospf interface
add network-type=broadcast passive=yes
add authentication=md5 authentication-key=*** dead-interval=6s hello-interval=2s interface=ether1 network-type=nbma use-bfd=yes
add dead-interval=10s hello-interval=3s interface="ether2.52 - Downlink to E" network-type=point-to-point use-bfd=yes
/routing ospf nbma-neighbor
add address=172.16.23.33 poll-interval=5s priority=2
/routing ospf network
add area=backbone network=172.16.201.10/32
add area=backbone network=172.16.23.32/28
add area=backbone network=172.16.52.0/27
Edit: The packets are considered invalid coming ‘in’ from ether2.52. I can block invalid packets everywhere except that interface
Have you tried to set ****
log=yes log-prefix=weird-rule
at the drop rule for a couple of seconds and see what packets in particular (source, destination, other info depending on packet type) the rule actually drops? A packet is marked as
invalid
by connection tracking if it does not fit to the current state of a connection, such as a
SYN, ACK
packet when
SYN
packet was not seen before.
As your diagram shows a linear topology, I can only imagine things like each direction of a connection going through a different VLAN or MPLS tunnel, e.g. because packets are src-nat’ed in one direction and this along with routing in another element makes them come back via a different interface.
