The question is how much (in relation to total number of packets) and what kind of packets. There are always some packets that stateful firewall sees as invalid. Some retransmitted ACKs, RSTs, …
You was absolutely right. I collected info from mikrotik to wireshark and analyzed traffic. All packets which were dropped by mikrotik is with retransmission status. Please check my diagram dependence total count of packets from retransmitted. Is it normal?
If I’m looking correctly and e.g. at time 140 it’s over 20% of retransmitted packets, then yes, it does look like a lot. But to be honest, I’m not sure what I’d do next.
A possible question may be does this have an effect to
a) browsing speed?(do webpages load up faster or slower when drop rule in place)
b) Does this have an effect on Upload or download speeds?
c) Does this effect windows scaling?(has anyone done a capture using wireshark running same tests to see if this affects windows scaling)
