forward port 80 for apache webserver
Hi i have a mikrotik rb751u-2hnd, i have in the ether3 a different ip address for apache webserver using ubuntu, im trying to make the apache webserver accesible from the outside from my public ip of my ISP, now i just can see the web locally using http://192.168.100.100 how i can forward or open port 80 to when i go to http://myispIP opens the apache webserver from the network 192.168.100.100?
i tried this
/ip firewall nat add chain=dstnat dst-address=213.198.239.100 protocol=tcp dst-port=80 action=dst-nat to-addresses=192.168.100.100 to-ports=80
but doesnt works
thank you very much.
How are you testing that?.. are you testing from behind the NAT? What do you mean “doesn’t work”?.. do you see any page? Does it timeout? What does the rest of your config look like… specifically the rest of the filter and nat tables. Post the exports.
Like efaden said how are you testing. If you are testing from inside, you also should create a ‘Hair-pin’ NAT rule.
Also check your firewall filter rules. You also must accept the connection there.
in my mikrotik i have a separate network with diff ip like 10.0.27.1 and i have a vmware machine with that ip and a webserver inside using apache, when i go to http://10.0.27.3 for example i can see the page, im testing in my own machine that have another ip 192.168.88.x, but if i go to my cellphone i try to point my public ip from my ISP example http://97.12.21.1 i cant see the website from http://10.0.27.3 i would like to make public the website from the ip 10.0.27.3 so i can access it remotely from a machine in other country or place.
its like when i had a linksys router for example i have a vmware machine with ip 192.168.2.2 then i just forward the port 80 for that ip then i can access my public ip form the outside or another country or device and see the website
right now i have this:
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=“default configuration” connection-state=established
add chain=input comment=“default configuration” connection-state=related
add action=drop chain=input comment=“default configuration” in-interface=
ether1-gateway
add chain=forward comment=“default configuration” connection-state=established
add chain=forward comment=“default configuration” connection-state=related
add action=drop chain=forward comment=“default configuration” connection-state=
invalid
add action=masquerade chain=srcnat comment=“default configuration”
out-interface=ether1-gateway
add action=dst-nat chain=dstnat dst-address=97.87.x.x protocol=tcp
to-addresses=10.0.27.3 to-ports=80
the 97.87.x.x is my wan ip, my public ip that ISP gave me and the apache website is on the 10.0.27.3
now when i try http://97.87.x.x from my own pc keeps loading and loading and shows after a while, unable to connect.
ok i fix it by adding a masquerade rule for 10.0.27.0/24 and worked perfect, but im not sure is this the best way to achieve this? i have this right now:
0 ;;; default configuration
chain=srcnat action=masquerade out-interface=ether1-gateway
1 chain=dstnat action=dst-nat to-addresses=10.0.27.3 to-ports=80
protocol=tcp dst-address=97.87.x.x dst-port=80
2 chain=srcnat action=masquerade src-address=10.0.27.0/24
but if my ip 97.87.x.x changes maybe once per month, what should i do?
Pretty sure you don’t really want to masq that way… but I did notice that your forward is set to default drop… you need to allow the port 80 traffic on forward for your dstnat to work.
what should i change? the rule in firewall? filter
invalid
i need to change this? or add a new rule
thank you.
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
ether1-gateway
established
connection-state=invalid
add action=dst-nat chain=dstnat dst-address=97.87.x.x dst-port=80
protocol=tcp to-addresses=10.0.27.3 to-ports=80
add action=masquerade chain=srcnat comment=“masquerade hotspot network”
src-address=10.5.50.0/24
i removed the masquerade for the 10.0.27.0 network
Add:
add action=accept chain=forward dst-port=80 in-interface=ether1-gateway
Above:
Or something like that…
You should also allow all forwards outbound…
add action=accept chain=forward out-interface=ether1-gateway
still no luck, i cannot see the website using my public ip:
add chain=forward comment=“new rule 2” dst-port=80 in-interface=
ether1-gateway protocol=tcp
ether1-gateway
established
add chain=forward comment=“new rule 1” out-interface=ether1-gateway
i dont know if im doing something wrong?
thank you.
I’m still a little confused… are you trying to hit the public IP from behind the mikrotik?..
yes ok, when im trying to achieve is, i have in 10.0.27.3 a webserver using apache i have a test website, i need to access that webserver using my public ip so i can access for example in other country or other device out my home network http://97.x.x.x so i can see the website, when i make the masquerade to 10.0.27.0 network, it worked perfect but when i disable it i cant see the website so now, i just can see the website from my own machine locally, but not in another computer or a friends computer.
its like when u have another router like linksys and in your pc u install apache to test websites but u need to access it via public ip, so you go to port forwarding and open port 80 and put the local ip of the machine, and then u can access public ip and see the test website. But i dont know how to achieve this using mikrotik
Right… but my question still stands. When you are testing to see if the port forward works… are you testing it from a computer inside of the firewall?.. or are you testing it from outside?
outside using my cellphone data, but when i create the masquerade then works perfect in my own machine and cellphone everywhere
oh no, let me see now its working without masquerade, but how i can make it so i can see it from my own machine using public ip? or i just can use the private 10.0.27.0? thanks
For that you need “hairpin”
http://wiki.mikrotik.com/wiki/Hairpin_NAT
Good it started working… couldn’t see any config problems so I was confused… you shouldn’t need to have a masq rule for dstnat… just the dstnat rule and possibly an allow in forward depending on your config.
to make it work in my own machine using public ip i need hairpin nat? will be like
add chain=dstnat dst-address=97.x.x.x protocol=tcp dst-port=80
action=dst-nat to-address=10.0.27.3
add chain=srcnat out-interface=WAN action=masquerade
Kinda… thats for your normal dst-nat… the hairpin is the redirect for within it…
You add something like this.
add chain=srcnat src-address=192.168.1.0/24
dst-address=192.168.1.2 protocol=tcp dst-port=80
out-interface=LAN action=masquerade
Those are all your private ips… …
