forward traffic to specific IP and port (v2ray local Server)
Hello
I have a local v2ray client windows on my pc (192.168.10.5) that enabled connection from Lan
So other pc on my LAN network could connect to the v2ray over Socks And HTTP on specific Port
for example on another PC, in firefox, we set the proxy to a manual HTTP proxy and enter 192.168.10.5 and port 8588 and Work Correctly!
as I search there is no socks or HTTP client on Mikrotik,
I Need my Mikrotik to manage users to route their traffic to v2ray local pc over socks or HTTP, if I want to clear I need forward some traffic to specific IP and port (v2ray local pc)
could you please guide me?
just install V2rayN in windows client
then in settings > basic settings: tick the “Allow Connection From the LAN” box.
ports 1090 & 1091 will open to use for other clients in local network access.
Hi
As you know the main problem in Iran is about how to route V2Ray traffic throughout the Mikrotik routers.
Im not experienced on networking, but i have problem at the moment.
My pc is running with two LAN card, im running mikrotik os via VMWARe machine and all functions are working fine.
ether1= incoming traffic , wan , ip= 192.168.1.2
ether2, dhcp server= 12.2.1.0/24
How to route V2ray to ether2?
Could you please explain detailed instruction about this scenario?
Nemisheh farsi moshkelto matrah kard?
Exactly my main problem is how to manage and control my traffic route in my mikrotik to v2ray
نمی‌دونم کسی براش راه حل داره یا نه
with SSTAP application and define hotspot in your windows and connect hotspot interfce to your main interface you follow up.
use OpenWRT appliance and install v2ray client on it , and route your traffic to OpenWRT router.
i very need that . please fully explain that . i need those files and how to implement ?
you can use chr router version7 or more
install enable container
install pi Hole Linux on it,
user v2 ray client on linux
route your traffice / mangle to linux
پارگی داره ولی میشه
