Create a walled garden entry for the web form you want filled out.
Reneme ahe default login page for the RouterOS hotspot to something like go.htm
Create a simple page on the router that on hotspot connect, sends them to the web form.
Edit the “go.htm” page to simply have a " splash screen IE “Sucess” or Thank You" etc and a button to procede (this would be an edited form of the trial button)
Make sure the trial function is enabled on the hotspot. And set the appropriate time limits.
You may also want to set some sort of client side flag to verify that the user filled out the form before allowing access to the trial function.. IE set a client side variable on the web form and test for it on the "thank you " screen, If the variable is not correctly set, force them to the web form (this would all be client side) also, I would set the trial button to disabled by default unless the variable condition was satisfied.
