Forward VPN Client to a particular interface
I have a RB951G-2HND. Internal network is 192.168.22.0/24. (Interface 2-4). I have a Netgear Router plugged in to port 2. Network behind the Netgear is 192.168.1.0/24. I want to plug Interface 5 in the 192.168.1.0/24 network. When a VPN client connects to the Mikrotik, I want it to be forwarded to the Netgear network only. I am using the Mikrotik as a firewall, so I don’t want to compromise my security. Is this possible? Thanks, for any help on this.
The simplest way would be to create forwarding rules in the firewall that don’t permit the VPN subnets to talk to anything but the 192.168.1.0/24 network. Alternatively, you could create a separate routing mark for the VPN traffic and it would be isolated to that routing table.
Something kind of like this..you can adjust and bypass as needed
add action=drop chain=forward dst-address=192.168.22.0/24 src-address=192.168.1.0/24
add action=drop chain=forward dst-address=192.168.1.0/24 src-address=192.168.22.0/24
add action=accept chain=forward
