Forward VPN connection to a single internal IP
Is it possible to do this and if so, how do I go about it?
I’d like to set up a PIA connection and have it only be active on one of the IPs. The IP is a jail on a FreeNAS system, therefore, I’m not sure assigning it to a physical port is best. A jail is pretty much like a VM for those unfamiliar with the OS.
Are you asking if it is possible to forward the VPN to the jail and terminate it there or do you want to terminate the VPN and then forward the traffic to the jail?
The first. I’d like the jail to be the only connected through the VPN. All other IPs to be left untouched.
