forwarded a port then no internet access and cannot Web OS
Hello everyone,
I am still new to MikroTik and today I was trying to forward a port but skipped a step and now my router doesn’t connect to the ISP’s static
I figured I can just go in there and get rid of the port but I cannot go into the web OS. The gateway (192.168.1.1:8080) doesn’t work is there any other way to go in there.
Below are the steps I made for the port forwarding.
IP > Firewall > NAT > Add New > Chain=dstnat > Protocol=6(tcp) > action=dst-nat > to addresses=192.168.1.200 > port=16016
The step I skipped by mistake was adding the port to Dst. Port
My router is a RouterBoard 750GL v5.24
Connect to your device with MAC-TELNET protocol; either you can plug a computer on the RB750 and launch winbox, either you have another mikrotik device connected to this device (all RouterOS can mac-telnet connect to their neighbours).
