I’m trying to use a pp2p vpn server to play network games with friends.
The connection works but we cannot see each other in the game.
After doing some research it turns out the udp broadcasts are required and don’t seem to work.
Any ideas on how to get broadcast packets from vpn connections to forward to other vpn clients and the local network?
Whether there is what information on the given question?
in 3.0 you can bridge tunnels on both ends and make a transparent broadcast network… if your using routing though its not easy.
I am running 3.0. How do I bridge my client pptp vpn connections?
