Hi there,
Hardware : RB2011
SW Version: 5.20
My problem is fairly simple, I have created 2 bridges {SwPublic and SwIntra} and there is
GPS information being broadcasted on SwPublic on port 3002 that needs to be forwarded back to SwIntra.
SwPublic : eth1, eth2, eth3
SwIntra : eth4, eth5 … eth9, eth10
I’ve added an IP address to SwPublic {172.22.66.100} and one to SwIntra{192.168.77.1}
Then I tried to forward the SwPublic broadcast to a broadcast to SwIntra like so:
/ip firewall nat add action=dst-nat chain=dstnat in-interface=SwPublic dst-address-type=broadcast dst-port=3002 protocol=udp to-addresses=192.168.77.255 protocol=udp dst-address-type=broadcast
That didn’t work so then I tried to redirect to a particular intranet IP like so:
/ip firewall nat add action=dst-nat chain=dstnat in-interface=SwPublic dst-port=3002 protocol=udp to-addresses=192.168.77.2 protocol=udp
For testing purposes, I’m using this script on my Linux server to broadcast the packets:
#!/bin/sh
while :
do
date -u | socat - UDP4-DATAGRAM:172.22.127.255:3002,broadcast
sleep 1
done
and this script does form nice broadcast packets using Wireshark I can see:
- Ethernet address = ff:ff:ff:ff:ff:ff
IPV4Dst=172.22.127.255
Dst Port= UDP 3002
But wireshark on the IntraNet does not show ANY packets with destination = 3002
I can see packets coming in in RB2011 /ip/firewall counters, I see my packet count increment for that rule, but NO packet broadcast or unicast on the SwIntra…
How can I follow the path of my packet and how it “disappears” in the IPChains ?
What did I misconfigure ?
Kind Regards,
Martin Politick.
This is the script I apply for a Virgin RB2011, if you have comments to bettrt this script in other areas (like removing the default configuration) please let me know:
#-- Set this manually for each RB2011
global MachineName Vehicle100
global MachineIp 172.22.66.100
global MachineMask 255.255.192.0
#-- Set this manually for each site
global MachineDns 172.22.64.9
global MachineGw 172.22.64.1
#-- This should be fixed for all vehicles
global IntranetIp 192.168.77.1
global IntranetMask 255.255.255.0
global IntranetNet 192.168.77.0/24
global DhcpdRange 192.168.77.200-192.168.77.254
global NAV 192.168.77.2
/system identity
set name=$MachineName
#--- Removing old configurations
#--- Renaming Interfaces
/interface set 0 name="eth1"
/interface set 1 name="eth2"
/interface set 2 name="eth3"
/interface set 3 name="eth4"
/interface set 4 name="eth5"
/interface set 5 name="eth6"
/interface set 6 name="eth7"
/interface set 7 name="eth8"
/interface set 8 name="eth9"
/interface set 9 name="eth10"
# Remove bridge between all ports
:foreach k in=[/interface bridge port find] do={
remove $k
:foreach k in=[/interface bridge find] do={
remove $k
#remove slave ports
set eth7 master-port=none
set eth8 master-port=none
set eth9 master-port=none
set eth10 master-port=none
#--- Setting up virtual switches
/interface bridge add name="SwIntra" comment="Vehicle Intranet switch firewalled"
/interface bridge add name="SwPublic" comment="Public radio side switch"
#--- Public side
/interface bridge port add bridge=SwPublic interface=eth1
/interface bridge port add bridge=SwPublic interface=eth2
/interface bridge port add bridge=SwPublic interface=eth3
#--- Intranet side
/interface bridge port add bridge=SwIntra interface=eth4
/interface bridge port add bridge=SwIntra interface=eth5
/interface bridge port add bridge=SwIntra interface=eth6
/interface bridge port add bridge=SwIntra interface=eth7
/interface bridge port add bridge=SwIntra interface=eth8
/interface bridge port add bridge=SwIntra interface=eth9
/interface bridge port add bridge=SwIntra interface=eth10
#--- Removing all IP addresses
:foreach k in=[/ip address find] do={
/ip address remove $k
#--- DHCP Client --- Don't ask for an IP address
/ip dhcp-client
:foreach k in=[/ip dhcp-client find] do={
remove $k
#--- dhcpd --- DHCP SERVER on Intranet
:foreach k in=[/ip pool find] do={
remove $k
/ip pool add name=DHCPd ranges=$DhcpdRange
#--- Change default DHCP IP address range so we know OUR config is applied
:foreach k in=[/ip dhcp-server find] do={
remove $k
:foreach k in=[/ip dhcp-server network find] do={
remove $k
#--- DNS
/ip dns static
:foreach k in=[/ip dns static find] do={
remove $k
#--- Remove NATTING
:foreach k in=[/ip firewall nat find] do={
remove $k
#--- Disable SIP from service ports ---
/ip firewall service-port
:foreach k in=[/ip firewall service-port find name~"sip"] do={
:put [/ip firewall service-port get $k ports]
disable $k
#---- Remove routing
:foreach k in=[/ip route find] do={
remove $k
#--- Rebuilding configuration
#--- Add IP addresses to the swithces so we can reach the RB2011
/ip address add address $IntranetIp netmask $IntranetMask interface SwIntra comment="Intranet";
/ip address add address $MachineIp netmask $MachineMask interface SwPublic comment="Public";
#--- static DNS on private intranet
/ip dns static add address=$IntranetIp disabled=no name=router
#--- DHCP Setup
/ip dhcp-server add interface=SwIntra address-pool=DHCPd authoritative=yes disabled=no name=dhcpd
/ip dhcp-server network add address $IntranetNet dns-server $IntranetIp domain politick.com gateway $IntranetIp
#--- Set Routing
/ip route add dst-address=0.0.0.0/0 gateway=$MachineGw
#--- Enable NATting for TCP and UDP
/ip firewall nat add chain=srcnat action=masquerade out-interface=SwPublic
#--- Secure the rest of the ports from the radio ----------------
/ip firewall filter add action=drop chain=input disabled=no in-interface=SwPublic dst-address=$IntranetNet comment="Radio"
#--- GPS info
#/ip firewall nat add action=dst-nat chain=dstnat disabled=no dst-port=3002 to-ports=3002 in-interface=SwPublic to-addresses=$IntranetBrod protocol=udp dst-address-type=broadcast
/ip firewall nat add action=dst-nat chain=dstnat disabled=no dst-port=3002 to-ports=3002 in-interface=SwPublic to-addresses=$NAV protocol=udp
#--- Remote Desktop
/ip firewall nat add action=dst-nat chain=dstnat disabled=no dst-port=3389 to-ports=3389 in-bridge-port=SwPublic to-addresses=$NAV protocol=tcp comment=Remote.Desktop
