Forwarding FTP Ports (DST-NAT) Passive mode
I’ve been forwarding FTP to an internal FTP server for years and it’s worked fine. I forward external ports 20-21 to internal ports 20-21. The FTP client log displays the external IP (assuming the IP is x.x.x.x)
227 Entering Passive Mode (x,x,x,x,22,72).
We have a blackberry user that needs to connect to our FTP but the blackberry service blocks port 21. We’ve setup a separate FTP service in IIS on port 5700. We’ve tested internally and it works but externally it doesn’t. I’ve forwarded external ports 5699-5700 to internal 5699-5700 and when the client connects there are 2 weird things about it
  1. Uses the internal IP instead of external in the client log:
    227 Entering Passive Mode (192,168,10,10,22,68).
  2. Gives the error:
    Response: 425 Can’t open data connection.
    Error: Could not retrieve directory listing
    I’ve tried narrowing down the # of ports that PASSV transfer uses (http://support.microsoft.com/?id=555022) and forwarding those ports too but it doesnt make a difference. Anyone out there had luck with this?
Anyone?
I believe there is no way to change the ftp-data port on windows ftp server. You can change the control port, but not the data port. Not 100% sure - maybe verify that.
