ok guys been working with mt for awhile . got everything figured out except how to get a bridge to work thru another unit..
let me explain. and maybe i am just doing incorrectly
i can get bridging to work just not at same time as nat on another nic
MT Main AP bridge 192.168.10.1/24 from here i can ping both units just a bridge
MT bridge AP 1 192.168.10.2 from here i can ping both the main ap and the station, this unit has wlan,ether1 bridged and ether2 nated to static 64.2.2.2/25 0.0.0.0=64.2.2.1 gateway vpn connection works also
now to this point everything works.
now the problem
MT station 1 192.168.10.3/24 from instide mt i can ping all 3 but cannot from ether1 to outside the MT . 192.168.10.4/24 not pingable from outside the station1
all 3 units have bridging on and proxy-arp enabled
i gave this unit a static 64.2.2.3/25 ip address gateway 64.2.2.1 now from the station 1 winbox i can ping everything just cannot ping from the other side of the MT
unit behind MT is 64.2.2.4/25
now this unit can ping the MT station 1 and MT station 1 can ping it just doesnt go out the bridge to the wlan to MT AP1
i can get it to work with nat but not what i want ..
what am i doing wrong… help please
now i can from
this unit behind(192.168.10.4) can ping the MT station 1 but doesnot go past the router .
i will draw a diagram of what i would like to be done so there is a better understanding of what i am doing
randy
just basic rules setup on all 3 MT’s
now the problem
now i can from
randy
http://www.srsnetworks.com/mikrotik/index.html
everything works to the station just need to figure out why bridge isnt working thru station . tried wds did not work . going to play with it again.
randy
