Forwarding Port 80 leads to the login page, not website
Brand new to using RouterOS, so please be gentle.
I’m hosting a website on 192.168.88.209:80, and I have set up records on Cloudflare that point to it. However every time I try to go to it, it comes up with the Mikrotik login page. This happens on every device, local or not. Even my friends say they see the login page.
I’ve tried changing Apache to use Port 81, then forwarding port 80 to 81, which yeilded the same results.
Seems that you need https://help.mikrotik.com/docs/display/ROS/NAT#NAT-HairpinNAT
Is 192.168.88.209 the client? Are you forwarding the external IP address to this machine using DSTNAT?
If so, trying moving the Mikrotik interface off port 80 or disable if if you don’t need it (using Winbox or command line).
x.x.88.209 is where the website is hosted. Is this the correct code to do what you suggested?
/interface ethernet disable ether1
Try to read and implement HarpIn NAT as in link.
I’m not really bothered about being able to access it on my own end, its that its also showing the same thing for everyone trying to access it externally.
You might want to share your config, so we can solve this:
/export file=anynameyoulike
As stated we need facts.
/export file=anynameyouwish ( minus router serial number, public WAN IP information ).
https://forum.mikrotik.com/viewtopic.php?t=179343
Hi all, sorry for the big wait. This problem is solved now. Turns out it was a DNS record that was wrong.
