Forwarding port traffic
i have a configuration problem…
i need this one: all requests passing through port 9000 must be redirected to an ip address 192.168.1.150 (it’s a server).
I’m a beginner with mikrotik and I need someone who can do it
best regards
Post your config
/export hide-sensitive file=anyname
Go to the terminal window choice in winbox and post in the command
Then go to your FILES choice in winbox and find the exported file and then download it to your desktop.
Then open it with notepad and cut and paste the the contents here but use the code brackets (to the right of Bold, Italic etc, the black square with white square brackets).
Before you hit the submit button make sure that you have removed your WANIP or anything else you dont want to share.
