I’m trying to forward port’s only for one IP.
As i understand i allow connect selected ip to port 5060 and connect to : 192.168.20.2 on port 5060
it’s all ok with settings?
Yes, your settings are correct.
Thx
You’re welcome
Hello..
For the same above scenario if I want to open ports for all private IP’s how would that be.
Thank you.
Neski:
djfrancis:
Thx
Hello..
Thank you.
Can you explain your question better?
Regards
tiger4020:
Neski:
djfrancis:
Thx
Hello..
Thank you.
Regards
Neski forwarded a port for only one single ip 192.168.20.2
If o would want to open a port for 192.168.20.0/24
How would I do that?
First learn networking basics. Then - problem solved before appearance.
The configuration is the same as Neski but the only thing you need is write your subnet address instead a IP direction.
Regards
Regards
I tried using the entire subnet.. in my case it is 172.16.1.0/24
I am trying to open steam (gaming server) ports, but still unable to do so.
