Forwarding remote desktop
Forward remote desktop between two radios behind the same AP with default forwarding turned off.
I configured them as such but they can not negotiate a connection with remote desktop.
[admin@Ptera65-66] /interface wireless access-list> pr
Flags: X - disabled
0 ;;; Forwarding configured to Allow Holbert to Remote desktop to Eaglepoint
mac-address=00:15:6D:EA:03:93 interface=Ptera65 signal-range=-120..120
authentication=yes forwarding=yes ap-tx-limit=0 client-tx-limit=0
private-algo=none private-key=“” private-pre-shared-key=“”
1 ;;; Forwarding configured to Allow Holbert to Remote desktop to Eaglepoint
mac-address=00:15:6D:F2:0E:90 interface=Ptera65 signal-range=-120..120
I tried interface=all but that did not work either.
What am I missing?
Do I need to write some special Firewall rules or something?
If clients are from the same subnet and can ping each other remote windows desktop at port 3189 should work.
M.
Windows Remote Desktop is 3389/TCP :wink:
Yes it was misstype.
But i still dont now if the clients are communicating each other.
