Hi, I am testing hotspot. When I open web page (test http or https) web browser show web is unreachable. Does not funct automatic forwarding to login page of hotspot. I scanned the ports with nmap tool and ports 64872 - 64875 are open. I have as client station Windows 10 and Android phone.
# sep/25/2019 11:02:46 by RouterOS 6.45.6
# software id = D0WF-K8C6
# model = RB941-2nD
# serial number = 93710A6C2368
add admin-mac=74:4D:28:5A:A0:2A auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=indoor \
mode=ap-bridge ssid=MikroTik-5AA02E wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add dns-name=t.cz hotspot-address=192.168.87.1 login-by=http-pap,trial,mac-cookie name=hsprof1 rate-limit=5M/5M trial-uptime-limit=5m \
trial-uptime-reset=10m
/ip hotspot user profile
set [ find default=yes ] shared-users=10
add name=hs-pool-1 ranges=192.168.87.2-192.168.87.254
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=hs-pool-1 disabled=no interface=wlan1 lease-time=1h name=dhcp1
/ip hotspot
add address-pool=hs-pool-1 disabled=no interface=wlan1 name=hotspot1 profile=hsprof1
add bridge=bridge comment=defconf interface=pwr-line1
/ip settings
set allow-fast-path=no
add interface=wlan1 list=LAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.87.1/24 comment=defconf interface=wlan1 network=192.168.87.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.87.0/24 comment="hotspot network" gateway=192.168.87.1
set allow-remote-requests=yes
/ip dns static
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new \
in-interface-list=WAN
add action=log chain=hotspot comment=hledani disabled=yes
add action=log chain=hs-unauth disabled=yes log-prefix=Pdr
add action=redirect chain=hs-unauth dst-port=80 in-interface=wlan1 log=yes protocol=tcp to-ports=64874
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.87.0/24
/ip hotspot user
add name=admin
/ip service
set www-ssl disabled=no
/system clock
set time-zone-name=Europe/Prague
/tool mac-server
/tool mac-server mac-winbox
I guess the device you use doesn’t detect that it is behind a hotspot.. As long as your configuration is correct then it has totally to do with your computer.
If you try with your mobile phone does the hotspot portal pop up???
Unfortunately, it is the same on mobile phone with OS Android 7.0. When phone showed notification about hotspot, I click on it, is open page on browser “connectivitycheck.gstatic.com/generate_204”. But page does not load.
Bingo!
Zacharia you are right,
If you don’t specify DNS on your dhcp server you wont be able to open hotspot landing page automaticaly, in most devices will open but some of them are not working.
Attention!
You must specify your hotspot gateway address as your dns server under DHCP > NETWORKS
Ok I have new knowledge. In stable RouterOS 6.45.6 the hotspot not forwarding to login page, but in older firmware 6.43.16 yes. The solution is downgrade.
I will not look for the latest firmware in which everything works. I think, this is a bug in ROS 6.45.6.
i have same problem with redirect to local /login.html, after downgrade to 6.44.6 its work. please fix. p.s.: RB750G
some details: when i open http page by domain. nothing happens, browser wait connection and reset it after tiomeout.
when i open 1.2.3.4 In broeser, its redirected to local hotsoit domain name and again wait connection, and reset it after timeout.
I have been trying the same thing since yesterday and have no results.
That’s crazy !
If I do a DNS on the gateway of the AP I come across the router’s management page.
With IP adress I come across the router’s management page.
On android I see the login page but no redirection possible even by putting a site in http for test (modification of alogin and login.html).
I am on RB760iGS hardware and have stable ROS 6.47.4.
