forwarding traffic to a specific WAN interface
Hello My friends..!
so i have RB951ui and want the LAN 4 + 5 ports on it to use port 3 as the WAN interface like this scenario.
the main WAN connection coming to the Mikrotik router from eth-1, the ip address of eth-1 that it get from this WAN DHCP Server is 192.168.1.111.
then i set eth-2 to give the ip in this range 192.168.10.100-192.168.10.200 so the ip address of the eth-2 is 192.168.10.1
now from this eth-2 port that have the range above, i give my express VPN router internet -connected eth-2 port from mikrotik to WAN port in my expressVPN router-
now from LAN on my express VPN router that have the ip range 192.168.132.1-192.168.132.254 i connect the eth-3 on mikrotik to it. and it take the ip 192.168.132.5
in the end i want to all traffic that leave the eth4 & eth5 to go through the VPN -ie: from eth-3- not from eth1, so how can i do that..?
anyone have any idea please..?
Draw a network diagram. see apps
https://forum.mikrotik.com/viewtopic.php?p=908118
here we are..
Makes even less sense… I have no idea how the MT connects to the internet, ISP modem (what is internet and what is ethernet cabling).
ISP modem
So basically it’s:
ether1 = WAN1 (DHCP)
ether2 = LAN1 (192.168.10.1/24, uses WAN1)
ether3 = WAN2 (DHCP?)
ether4-5 = LAN2 (?.?.?.?/?, uses WAN2)
Correct?
yes that’s correct ..!
ether4-5=LAN2 with ip range 192.168.1.1/24 and it contain only the VPN traffic -ether3 - so all LAN2 traffic pass through ether3 only not ether1.
Scenario 1: LAN1 users go to WAN1 due to lower distance of WAN1, if WAN1 is not available users will go to WAN2. LAN2 user are only allowed to use WAN2.
dst-address=0.0.0.0/0 gwy=ISP1 table=main distance=1 check-gateway=ping
dst-address=0.0.0.0/0 gwy=ISP2 table=main distance=2
dst-address=0.0.0.0/0 gwy=wireguard table=useWG
/ip table
add name=useWG fib
/ip route rule
add src-address=192.168.1.0/24 action=lookup-only-in-table table=useWG
Scenario 2: LAN1 users go to WAN1 and are not able to use WAN2. LAN2 user are only allowed to use WAN2.
dst-address=0.0.0.0/0 gwy=ISP1 table=useWAN1
/ip table
add name=useWAN1 fib
add name=useWG fib
/ip route rule
add src-address=192.168.10.0/24 action=lookup-only-in-table table=useWAN1
A problem I see is that if LAN2 has 192.168.1.1/24 and WAN1 gets 192.168.1.111, it’s same subnets on two diffent interfaces, such thing generally doesn’t work well.
Hello Mr Anav..!
so i will try your method and give you the out put .
i was trying to use a amngle rule to apply that, i used mark connection and mark routing in sequense, but i didn’t get what i want, i think your
rules above will solve the problem.
my best regards.
Mangle rules are also useful in certain situations. In this case it can be solved in various ways.
The problem with directing a LAN outside to a specific wan by routing rules then prevents lanA to talk to lanB for example.
However solvable by adding another routing rule with dst=LANB, placed before the lan to WAN routing rule in order./…
Mangle is good when you need to ensure remote originated traffic coming into one WAN goes out the same WAN. In your case I believe that
your concern is only outgoing traffic (local originated traffic).
Hello Mr anav..!
so ok i apply your steps above and it work well ..!.however, what if i want to a specific ip address to exceed this rule, i mean from LAN2 i want two IPs to go through original WAN1 not WAN2 what i have to do in this scenario..?
do i have to create a new route rule for it in this case ..?
why i want to do this..?
well as i mention the incoming traffic from WAN2 is a VPN traffic and i want for a specific devices to not use it.
If you need two specific IPs to go through the normal wan just put two routing rules for them before the one that forces them out wan 2
add src-address=IP1 action=lookup-only-in-table table=main
add src-address=IP2 action=lookup-only-in-table table=main
thnx anav , i was searching for this solution for some time for my ccr2004, but your method is simple and elegant, works like charm
