hi
i need to forward vpn connection for users
they are using hotspot shield programm to avoid national proxy to access blocked websites
it is vpn connection with special server in the web
it from anchorfree(dot)com
once the user turns the programm on, he/she is diconnected from my isp
no surffing atall
check the logo
THAK YOU ALL
I GOOGLE IT > NO SUCCESSS
DID A LOG IN FIREWALL
I FOUND
forward: in:bridge1 out:pppoe-out1,
src-mac 00:15:6d:d4:dc:4b, proto UDP, 10.0.0.5:54687->64.62.196.138:8041, len 1
01
AND THEN FOR REST
AS FOLLOW
LOCAL PORT : IP : PORT
xxx : 69.31.101.61 xx
2035 : 69.22.184.159:8046
2210 : 68.68.102.75 : 8045
2258 : 69.22.184.164 : 8043
2444 : 69.22.184.163 : 8045
FOLLOWING ONE OF THE USERS WHO USES SWITCH AND THE PROGRAMM WORKS WITH HEM WITH NO PROBLEMS
N.B I USES FIRWALL FOR PORT SCANNER (MY BE CAUSE THE PROBLEMS)
PLEASE HELP ME IN FORWARD THE ABOVE RESULTS
I’M NEW IN MIKROTIK
